White smoke when starting.
Old Jun 18, 2007 | 08:17 PM
kayosnes's Avatar
kayosnes
Default White smoke when starting.
When i starts my car i have a lot of white smoke. But once it starts to warm up it is like normal. Youst wondering if the reason for this is that the compression is higher when the car is warm????
Annyone know?
Old Jun 18, 2007 | 09:04 PM
a1sensei's Avatar
a1sensei
White smoke is water. Either you have a notable amount of condensation from the weather when you start it, or you have a leak, most likely at the intake manifold. God bless, Sensei
Old Jun 19, 2007 | 12:45 AM
Steve COSD's Avatar
Steve COSD
Head gasket. Go for the side that the exhaust is white if you have dual exhaust. You may even try retorqueing the head.
Good Luck
Steve
Old Jun 19, 2007 | 02:03 AM
kayosnes's Avatar
kayosnes
Some new gaskets for me then.
Thanks for info
Old Jun 19, 2007 | 10:53 AM
lars's Avatar
lars
I doubt you have a water problem. If you did, you would get steam out the exhaust regardless of whether you run the engine hot or not, and you'd be consuming anti-freeze. Is your coolant level dropping?
A puff of white smoke out the tailpipes on initial startup is generally oil. If you look close, you'll probably see a blue-ish hue to the smoke. After engine shutdown, oil will seep down the valve guides and into the combustion chamber. On startup, it will burn out and cause the "white" smoke. You won't get it when you re-start the engine hot since the oil hasn't had time to seep back down again, but let it sit long enough, you'll get the puff.
Replace your valve seals as a start. If your car has about 100,000 miles on it, the guides are likely worn, too.
Old Jun 20, 2007 | 02:38 AM
kayosnes's Avatar
kayosnes
Well, my colant level is dropping some. But we are talking about small volumes. I fill up the expansion tank aprox 2 times a year.
I will look closer for the blue-ish hue to the smoke.
Maybee i have some of both.??
Old Jun 20, 2007 | 03:48 AM
wiseman79's Avatar
wiseman79
Valve seals will likely clear it up. I've done them on every small block I've had that any decent amount of miles and it's exactly as you've described.
To White smoke when starting.
