a crazy wiper door
Old Jun 19, 2007 | 04:06 PM
ohfiver's Avatar
ohfiver
Default a crazy wiper door
I have a 72 BB whenever I start the car the wiper door opens and then closes. Any suggestions?
Old Jun 19, 2007 | 04:34 PM
...Roger...'s Avatar
...Roger...
You have a little leak somewhere.Possibly the 3 port check valve.
Edit -try this-start engine and let vacuum build-pinch the hose between 3 port valve and the manifold-shut the engine off-restart engine-if the door doesnt go up and down then it was the 3 port valve.
Old Jun 19, 2007 | 04:37 PM
7T1vette's Avatar
7T1vette
Could be the check valve, or a plugged filter (in the same line from the intake manifold), or a malfunctioning wiper solenoid valve/switch gizmo on the back of the tachometer (driver's dash). You will need a vacuum gauge to diagnose the problem.
Old Jun 19, 2007 | 07:55 PM
ohfiver's Avatar
ohfiver
Thanks guys, I will be pinching my hose and checking my gizmo tonight.
Old Jun 19, 2007 | 07:59 PM
mrvette's Avatar
mrvette
Don't pinch your hose TOOO tight, you may hurt it.....
To a crazy wiper door
