Cylinder head install question
Old Jun 21, 2007 | 07:15 PM
70L46's Avatar
70L46
CF Pit Crew
Cruise-In I Veteran
Cruise-In II Veteran
Almost CI III Veteran
Cruise-In IV Veteran
Default Cylinder head install question
Had a blown head gasket on my '70 L46, so the heads are off and at the machine shop. When I reinstall, do any of the head bolts other than the row nearest the exhaust manifold need thread sealer? Is permatex OK, or is something else recommended?
Old Jun 21, 2007 | 10:05 PM
Scott Marzahl's Avatar
Scott Marzahl
Which Permatex, they have lots of products. Use one that is stated compatible with coolant and I install it on all the bolts. I use ARP thread sealant, I've used Fel Pro Grey Bolt prep and 3M weatherstrip adhesive works great too.
Old Jun 21, 2007 | 10:32 PM
big_G's Avatar
big_G
Most sbc head bolts go into water. I just seal them all.
Old Jun 22, 2007 | 12:21 AM
Oldguard 7's Avatar
Oldguard 7
Yup....Put sealant on them all.
Old Jun 22, 2007 | 11:31 AM
DL9179's Avatar
DL9179
I just did mine a week ago and used thread sealent high performance from pep boys and yep put it on all of them .
Old Jun 22, 2007 | 12:03 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
I used permatex Thread Sealer on all head bolts.
Old Jun 22, 2007 | 12:23 PM
70L46's Avatar
70L46
CF Pit Crew
Cruise-In I Veteran
Thanks guys!
Old Jun 22, 2007 | 01:03 PM
redwingvette's Avatar
redwingvette
Hows is it going Bill. I use non-hardening Permatex #2 on all of them.
It's about time you started working on the 70 instead of playing with the C5 all the time.
To Cylinder head install question
