Spring swap question
Old Oct 27, 2001 | 11:40 PM
thebruce's Avatar
thebruce
Default Spring swap question
To match my new cam, I'm swapping valve springs. The valve spring compressor seems to be cooperating, and I knocked out the first two no sweat. Now I'm stuck. I can't get the next valve to stay up (closed) while I push down on the compressed spring to get the locks out. Any way to do this other than air in the cylinder through the spark plug hole?
Thanks. :cheers:
Old Oct 28, 2001 | 12:09 AM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Spring swap question (thebruce)
Try a thin piece of nylon cord, about 1/4" - 1/3" in diameter. Poke as much as you can in through the sparkplug hole. The cord will keep the valves from dropping down. You should also have that cylinder to top dead center.
Old Oct 28, 2001 | 12:16 AM
thebruce's Avatar
thebruce
Default Re: Spring swap question (Smokehouse69)
I would never have thought of that. I'll get back at it tomorrow. Thanks for the help. :flag
To Spring swap question
