Speedometer cable squeek
Old Jun 23, 2007 | 05:35 PM
njcardave's Avatar
njcardave
Default Speedometer cable squeek
The speedometer cable on my 75 coupe has a squeeking sound that is very annoying. Should I try to lube it with the grease gun adapter or is it very difficult to replace with a new cable?
Old Jun 23, 2007 | 05:37 PM
dannyman's Avatar
dannyman
Graphite powder!!!
Old Jun 23, 2007 | 08:37 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Spray lithium grease.
Old Jun 23, 2007 | 10:01 PM
gldnkngt's Avatar
gldnkngt
are you sure it's the cable and not that the speedometer mechanism itself isn't the culprit. They've been known to squeal a bit.
Old Jun 23, 2007 | 10:04 PM
Hadez's Avatar
Hadez
sorry to thread jack but I am having a similar problem in that my speedo is ticking at certain speeds. From 40~60 and then 80~100mph it ticks. I use to have a ton of grease in my cable from previous owner as after a longer cruise (2+ hours) the grease would drop down onto my left foot!!!! It does not do this so much anymore. Any ideas where to start??? Speedo or cable?
To Speedometer cable squeek
