Harmonic balancer
Old Jun 24, 2007 | 09:49 AM
hwt03's Avatar
hwt03
Cruising
Default Harmonic balancer
The balancer has slipped on my 1980....besides not being able to set the timing, is there any problem with driving it? I want to enjoy cruising this summer and will add it to the todo list for the winter.
Old Jun 24, 2007 | 10:32 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Yes, there is a risk that the outer ring will come off and do significant damage. The outer ring is pretty heavy and only held in place by a bonding band of rubber to the inner ring and if it has slipped, the bonding layer is certainly going.
Old Jun 24, 2007 | 05:32 PM
Bullyj's Avatar
Bullyj
Old Jun 25, 2007 | 09:17 AM
Trae1976's Avatar
Trae1976
When mine slipped, it started chewing up the front cover. Fortunately I was pulling the engine anyway, so no further damage was done.
Get that thing out ASAP!
Good luck.
Old Jun 25, 2007 | 10:00 AM
TotalC1971's Avatar
TotalC1971
The balancer is also "balanced" to the engine as well.Driving with a slipped balancer is catamount to driving an "out of balance" engine and could also do internal damage as well. Get an ATI or Fluidamper!
Old Jun 25, 2007 | 11:13 AM
SteveG75's Avatar
SteveG75
Actually, the 350's are internally balanced. The balance will not change if the ring slips. The only small block that uses the balancer to actually balance the engine is the 400.
Old Jun 25, 2007 | 12:50 PM
lars's Avatar
lars
Once the outer ring slips, it can actually come off and fail completely. The last one I saw that slipped did the following:
We noticed that the balancer had slipped, so we did a TDC verification to establish a new timing line just to get the timing set. Once we set the timing, the owner drove the car home at 65 mph....
At 65 mph, the ring then separated from the balancer and exploded. This ripped the entire balancer apart, ripped the timing chain cover off the engine, tore the water pump off the front of the block, and cut the upper and lower radiator hoses. The exploding parts destroyed the fan shroud, fan, and pulleys. The parts had enough energy that pieces of the balancer hit the exhaust manifolds and sheared the manifolds off the cylinder heads, ripped the clutch dustcover off the bellhousing, and broke the bellhousing in 3 pieces.
Other than that, there was no problem driving the car with a slipped balancer...
Old Jun 25, 2007 | 02:12 PM
77BuffaloVet's Avatar
77BuffaloVet
'nough said...
To Harmonic balancer
