Easy C3 power upgrades
Old Jun 24, 2007 | 01:42 PM
guitarcrazy02's Avatar
guitarcrazy02
Default Easy C3 power upgrades
I'm sure it's been posted before, but I've got a 1981, and I'm looking to get just a little bit more power and torque out of my motor. 190 horse and 280 torque just isn't cutting it. I already put a K&N air filter and am about to put a new undercar chambered exhaust on in the next few days (waiting on the FedEx man). But without any major surgery or big $$$, is there any way to squeeze some more power out of my car?
Old Jun 24, 2007 | 02:08 PM
SteveG75's Avatar
SteveG75
Headers
Cam
Heads
In order of complexity and $$$.
Old Jun 24, 2007 | 02:20 PM
Glensgages's Avatar
Glensgages
I believe '81s had the first ECM-controlled ignition and/or fuel-management system, and it is possible that without disengaging this, your options may-be limited.
Old Jun 24, 2007 | 02:33 PM
guitarcrazy02
In response to Glengages, I should say that all computer controlled anything on my car is disconnected. I'm running a 1980 carb, as opposed to the 1981, since it would not work without the computer. So basically, it's a 1980 motor.
Old Jun 24, 2007 | 02:43 PM
Glensgages's Avatar
Glensgages
I had an ex brother-in-law who used the motor from an '81 Z28 for his hot-rod, and I recall the distributor couldn't be re-curved because it relied-on ECM input (something like that????? been many-moons ago, and I forget..... ), and he eventually had to use an aftermarket ignition:
somebody who's built an '81 can probably offer correct information.
Assuming I'm wrong (again ), what works on any SBC will work for your '81..... using GM-parts, the old #151 cam with better induction & exhaust should result in better performance, while retaining streetability on pump-gas:
I'd think your rear-gearing is very-tall, and killing off-the-line acceleration.
Old Jun 24, 2007 | 04:05 PM
guitarcrazy02
Based on the general principles of how a smog pump works, I'm guessing that's probably killing some power. I'm thinking about just cutting the belt to free up some load on the motor, as well as not injecting exhaust gasses into my intake. Anything I should be worried about with that?
Old Jun 24, 2007 | 06:23 PM
Vette80regon's Avatar
Vette80regon
I have an 80.
Before these mods I could barely squeek the tires.
1. Stans Tri-Y Headers
2. Cut & got rid of the AC
3. Cut & got rid of the AIR pump
4. MagnaFlow 40's
The engine was bored 30 over & a street cam was installed. Then, the edelbrock hi-rise intake & edelbrock performer 600 carb were installed.
Now, the car can leave two handsome black peelies wherever needed
Oh...The 80 has 3:55 rear. I think the 81 is taller (3:09???).
Definitely get headers before buying a chambered exhaust.
A chambered exhaust is more $ than the other mods listed.
AP
Old Jun 25, 2007 | 12:25 AM
glen242's Avatar
glen242
Did you notice any improvement after you put on the K&N??
Old Jun 25, 2007 | 02:08 AM
gingerbreadman1977's Avatar
gingerbreadman1977
the biggest killer on the 81 model is the gearing on the diff. it came with either 2.74 in the autos and possibly 3.07 in the manual . these gears are yuck !! get them replaced with some 3.55 gears and you car will boogey a little bit better . secondly put a 2500 stall in it and you wont believe the difference. its not all about the motor . you can run a 425 hp motor for example with the stock 2.74 and it will still bog down of the line. but a WARNING ..anything you do with DIFF,STALL and ENGINE = bye bye fuel economy !!!
Old Jun 25, 2007 | 08:54 AM
guitarcrazy02
There was a little bit of improvement from what I can tell. I mean, it was only around $20, but ya, there was a tiny little bit. Not the same difference you'd get from a cam and a set of heads, but it's somewhat noticable. But hey, now when I give the car some gas, it whistles a little!
Old Jun 25, 2007 | 09:22 AM
IrishJoker's Avatar
IrishJoker
That's sorta close and a common mistake since all later computer controlled Corvettes (C4-through C6) call the computer the ECM. On 1981 "ECM" is the Electronic theft deterrent Control Module and the Computer that controls the distributor advance and the carberator is called teh "CCC", for Computer Control Computer.
I'm not being a smart a** here on this point, I'm dealing with an ECM issue and my horns blowing and I need a new/rebuilt module, Zip says they rebuild and Corvette Central says they have the ECM, what they really have is the CCC for sale. So all you 81 owner be darn sure of what you order. I think Dr. Rebuild is the only one that knows the difference between ECM and CCC on the 81
Old Jun 25, 2007 | 09:24 AM
IrishJoker's Avatar
IrishJoker
Actually the diff is 2.73 with the manual tranny option.
Old Jun 25, 2007 | 09:28 AM
guitarcrazy02
You seem to be a pretty knowledgable person. Any idea on what the wires coming out of my smog pump are? Like I said, my computer is disconnected, but I'd rather be a little over-cautious and make sure I'm not hurting anything by cutting the belt on the pump to free up some power.
Old Jun 25, 2007 | 09:31 AM
Tim H's Avatar
Tim H
What woke mine up before doing all the other stuff is, A new $50 distributar from Whiteperformance on E-bay,wires.
Set your idle timing at 11 and total at 36@2500 RPM.
Theres no use doing anything until you max out the basics.
(PS) also set your carb idle air mixures screws with a vacuum gauge until you get the highest reading on the gauge, which should be about 1.5 more turns out.
Old Jun 25, 2007 | 09:44 AM
SIXFOOTER's Avatar
SIXFOOTER
Those wires actually go TO the smog pump assembly from the CCC and control relays for the diverter valve and annother valve, both having to do with when and how the air from the pump is delivered and where. If you want to delete the pump, you can do that, just don't expect another 35hp out of it. The pump may use 5 or 8 hp max. What it does do, it push fresh air into the exhaust stream at the header to keep the gas hot as possible in order to keep the cat functioning effeciently. You would probably realize more "NEW" HP by going to a Hi Flow cat or dual cats and dual exhaust. If you look at the plumbing on the air pump you will also see that there is a pipe coming from the pump that dumps excess head pressure into the intake system, cheap version of pass thru supercharging,
So, if your looking for cheap or easy hp, start with the exhaust, open it up to breathe. Stick a better cam in there, then maybe better heads.
Old Jun 25, 2007 | 10:01 AM
guitarcrazy02
http://i32.photobucket.com/albums/d5...t/PICT0285.jpg
There's the wires i was talking about
Old Jun 25, 2007 | 10:02 AM
UKPaul's Avatar
UKPaul
Stock rear on an auto '81 is 2.87:1 (2.72:1 for manaul?). This is great for economy but bad for performance.
The smog pump can removed with no problems (if it's legal to do so).
You say that you've got an '80 carb, but have you also changed the dist? If the stock dist is still in place, and the computer has been disconnected, there won't be any spark advance & it'll be like driving a slug.
The problems, for performance, with an L81 are that it's got low CR & can't breath (just like any smog model). Changing the stock Y pipes to duals (or chambered), makes a big difference. The next bung in the system is the heads & cam. The intake side isn't so bad & I'm not convinced that swapping out the stock manifold on mine was worth the $'s.
Headers will help, but nowhere near like duals/chambered will do. The stock manifolds are restrictive, but I found that they only start being a problem at higher rpms. At low/mid-range I didn't notice any difference between headers & stock manifolds. If you change to headers make sure that you check the carburation afterwards - I had to change the secondary rods to DA (from CH) but I don't know if mods will be needed on the primary side (I've still got a computer taking care of all that).
To Easy C3 power upgrades
Old Jun 25, 2007 | 10:59 AM
Glensgages's Avatar
Glensgages
I believe you are correct about the ECM/CCC stuff.....
I hate ALL that ****, and can't wait to remove it from my '82 Cease-Fire.
Old Jun 25, 2007 | 11:13 AM
karioth's Avatar
karioth
do the basic stuff... (in order)
1. Full tuneup (spark plugs, wires and dizzy cap)
2. replace filters (fuel, air)
3. advance timing (someone else mentioned this)
4. Rear end gearing
If you need more power than that and you gotta start buying real parts. Be aware that almost anything that gets you more power eats more gas.
Old Jun 25, 2007 | 11:34 AM
IrishJoker's Avatar
IrishJoker
LOL no actually SIXFOOTER is more of an expert on this stuff - I've just been doing some major electrical stuff myself and run across a few of my own Bubba wiring nightmares. I had a "HORN" blowing problem which I tracked back to the ECM module (alarm system). I think Danny answered you under your post on how to track down the harness wires.
