Anybody try Year One's Crate Engine...
Old Jun 26, 2007 | 12:40 PM
OregonVette80's Avatar
OregonVette80
Default Pump gas?
I have kicked around the notion that when my current motor has "dried up" that I would entertain the idea of a crate engine. My biggest question is that I want to keep the car able to run on 87 Octane "regular pump gas."
Is is possible to find a 400hp crate which is able to run on regular pump gas (87 octane)?
Old Jun 26, 2007 | 08:02 PM
OzzyTom's Avatar
OzzyTom
Sure.... get a big block with 8.5:1 compression.
Old Jun 27, 2007 | 04:53 PM
Cory1970's Avatar
Cory1970
Originally Posted by spedaleden
I looked at them but I think there GM Crate motors with a year one part number. I was able to get my motor cheaper from GM parts dept.
They are not GM crate motors with Y1 part numbers.
Old Jun 27, 2007 | 05:07 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
I have it. it dynoed 425hp 438tq. still fighting a off idle hesition im not using the 1 inch space that they dynoed with it. Motor is build by derebery preformance or hi tech preformance. its a clone of a zz430 i say go for it. Im happy with it.
Old Jun 27, 2007 | 05:13 PM
jhuff's Avatar
jhuff
what kind of gas do they run on? 91?
Old Jun 27, 2007 | 05:34 PM
Silver00V6Camaro
91 minimum. so 93 is what i run only place that sells 91 here in alabama is kangaroo gas.
Old Jun 27, 2007 | 06:39 PM
Tankers's Avatar
Tankers
I bought mine straight from Dereby performance who builds the engines that year 1 sells. I went to the shop in Texas and watched them dyno it. We did it with their carb and dist. Then we switched to my carb and dist and dynoed it again. Great motor and company.
Old Jun 27, 2007 | 07:15 PM
hap1971's Avatar
hap1971
I pulled the trigger on this engine today - Y1 told me 2 weeks minimum, 3 weeks likely, definitely less than a month. I am very excited.
I am putting this engine in w a T56 6 speed trans out of a 95 Camaro.
I asked and they said the engine is internally balanced, 1 piece seal crankshaft.
I know the LT1 engine has balancing weight on the factory flywheel, so what should I do for a flywheel? Just get it balanced?
Old Jun 28, 2007 | 07:21 AM
ajrothm's Avatar
ajrothm
What did it dyno?
Old Jun 28, 2007 | 09:22 AM
Jims79's Avatar
Jims79
Wish I saw this crate before I spend more then that building my new motor. looks like a great deal and has a warranty mine doesn't.
Old Jun 28, 2007 | 04:47 PM
corvetteterry's Avatar
corvetteterry
I live about 2 miles from year one and i saw the post yesterday and decided to go by their today and check them out. they have about 8 engines in stock all range in horse power up to about 420. i think i will pick mine up to.what do you guys think we could do to increase the horsepower a little more
Old Jun 28, 2007 | 04:58 PM
sperkins's Avatar
sperkins
Me too.
Old Jun 28, 2007 | 05:56 PM
  #33
jcswm's Avatar
jcswm
Originally Posted by ajrothm
Thats a HELL OF A DEAL!
I Never in my wildest dreams thought someone would say that about Year One
Old Jun 28, 2007 | 06:38 PM
  #34
Tankers's Avatar
Tankers
What did it dyno?
408.2 HP at 5700RPM and 425.9 tq at 3800 RPM
Old Jun 28, 2007 | 10:24 PM
  #35
bozzman3's Avatar
bozzman3
Found the thread http://forums.corvetteforum.com/show...E+CRATE+ENGINE
Old Jun 28, 2007 | 11:09 PM
  #36
Silver00V6Camaro
Originally Posted by bozzman3
that was at the rear wheels the numbers being posted in this thread are at the crank. So fiqure in drivetrain loss with the IRS and What ever tranny and those #'s are probably a good indication of RWP. Just read that post again he had a 3000 stall thats one problem right there. This motor will do great with a factory to small stall converter. That is what I was told by derebery before i bought the motor. A 3000 stall sucks on the street my old motor had it and did not do crap until 3000 when the converter would flash had to have it due to the big cam edlebrock performer rpm cam.
Old Jun 29, 2007 | 07:42 AM
  #37
corvetteterry
some people just dont understand that a 420 hp engine their still a lot you have to you have to do to the car to try to keep that hp
To Anybody try Year One's Crate Engine...
Old Jun 29, 2007 | 09:55 AM
  #38
bozzman3's Avatar
bozzman3
How does a loose converter effect horsepower on the dyno?Once the converter flashes your horsepower should be the same,unless the flash rpm is higher in the rpm band in respect to the engines HP output. Are all these Year One engines dynoed?When those Hp figures are given are they dynoed with accessories?Anybody have any RWHP numbers for this engine?I am not trying to bash this engine but the #S seem so high for such a small $ amount.
Old Jul 2, 2007 | 11:00 PM
  #39
hap1971's Avatar
hap1971
Got my engine already!!! (Less than a week turnaround time).
411hp,426tq.
I noticed that the supplied flywheel has a balancing weight.
Y1 told me the engine was internally balanced before I ordered it.
Im no engine guru, but if theres a weight on the flywheel, that means its balanced externally, right? I need to know so I can get the correct flywheel for the T56 conversion. Does anybody know more about this engines balance?
Old Jul 3, 2007 | 12:02 AM
  #40
sperkins's Avatar
sperkins
411hp,426tq.
Flexplates are balanced like all things by the use of weights. Some have little weights, some have big weights. Flywheels used with internally balanced engines are zero balanced. This means a flywheel and engine are in balance whether they are together or not. It also means the zero-balanced flywheel can be indexed on the crankshaft in any position without affecting the balance of the whole assembly.
