Vacuum advance
Old Jun 25, 2007 | 06:16 PM
artmaki79's Avatar
artmaki79
Default Vacuum advance
Would moving the vacuum advance from the carb to the intake manifold change the miles per gallion?
Old Jun 25, 2007 | 06:41 PM
Disco_Mike's Avatar
Disco_Mike
Im no expert,
but it is actually ported vs manifold vacuum pressure that matters.
The QJet has both ports on it.
Old Jun 25, 2007 | 06:51 PM
artmaki79's Avatar
artmaki79
Originally Posted by GotNoMojo
Im no expert,
I forgot to add, it's a 600 Edlebrock.
Old Jun 25, 2007 | 07:18 PM
Big2Bird's Avatar
Big2Bird
Try it. It will probably run better anyhow.
Old Jun 25, 2007 | 07:47 PM
...Roger...'s Avatar
...Roger...
Yes
Old Jun 26, 2007 | 10:05 AM
artmaki79's Avatar
artmaki79
Originally Posted by DWncchs
Yes
better or worse???
Old Jun 26, 2007 | 10:15 AM
lars's Avatar
lars
The carb has 2 types of vacuum sources on it: Ported vacuum and manifold vacuum. It doesn't matter whether you change the vacuum from the carb to the manifold. It matters if you change from ported vacuum to manifold vacuum. Manifold vacuum is available at the carb or at the manifold. Changing from ported vacuum to manifold vacuum (by changing the vacuum hose from one nipple on the carb to the other) will change engine efficiency and fuel consumption at very low throttle openings, but not at cruise speed where ported vacuum and manifold vacuum is the same.
Old Jun 26, 2007 | 11:49 AM
...Roger...
better or worse???
I knew you were going to ask that and I cant honestly say.I can tell you several years ago I tried ported verses manifold on my own car and I know the manifold made the car more responsive but I think I got better milage on the ported.If it would have been a bunch I think I would have remembered.My car was driven in town only for that little unprofessional test over about a month.Maybe Lars can say which way is best in theory for milage in town.
Old Jun 26, 2007 | 11:53 AM
artmaki79's Avatar
artmaki79
thanks,
To Vacuum advance
