emblem attachment
Old Oct 28, 2001 | 02:04 PM
daniel77350's Avatar
daniel77350
Default emblem attachment
Today I decided since it was so cold I would do an inside job. So I took the emblems off my car so I could clean/repaint them(the black white and red parts)...the question I have is this:
For the side and front emblems, since they are not attached with screws, how are they attached...the emblems came off with little effort, in fact Im suprised they stayed on while driving. Is that correct? or should the be on there a little more firmly? I see what appears to be a black double sided take like thing on the back of the emblems, should this be more sticky? And is that what holds them?
If it is, can I use some servo tape(for R/C use), to tape them back on? or will the tape be to strong? Or just some black silicone....what do you guys suggest.
Daniel
Old Oct 28, 2001 | 02:49 PM
jerryp58's Avatar
jerryp58
Default Re: emblem attachment (daniel77350)
I can't comment on the suitability of servo tape or black silicone, but I can tell you that the replacement front emblem I bought from Zip was mounted with two sided tape.
It's on there nice & firmly now, versus the previous one that flew off while I was driving down the Interstate one day. Losing the emblem was bad enough, but it had to hit the back deck of the car and chip the paint on its way out :mad
Old Oct 28, 2001 | 03:21 PM
Paul L's Avatar
Paul L
Automotive stores sell 3M double-sided tape for this purpose. You will find it near the 3M weatherstripping adhesive.
Old Oct 28, 2001 | 04:35 PM
ZD75blue's Avatar
ZD75blue
Default Re: emblem attachment (paul79)
i thought that they were held on with those acorn bolts (is that the name?) and they had a screw that went through the fiber glass... or am i talking about another emblem? maybe the fuel door
ZD (75)
Old Oct 28, 2001 | 06:07 PM
daniel77350
Default Re: emblem attachment (ZD75blue)
the fuel door is acorn nuts...the other 3 have studs to locate the emblems, then a double sided tape to secure them...
Daniel
To emblem attachment
