Need advice about rebuilding an engine
I have a 1970 small block. I have been dreaming about re-painting it for years. Now, the more I think of it, I would like to re-build the engine and make all of that look nice and mechanically sound before I drop the money on paint. It's a numbers matching car.
So my question is this...how much (on average) should I expect to pay someone to re-build my engine and make it "good as new" including re-painting it so it's pretty?
Further - are there things I can do to save a good amount of this cost? Now, keep in mind I am not even close to as knowledgable about all of this as you guys are. I like to think I'm mechanically inclined and well educated with more degrees than I care to admit in public. But if I did something like this, I would have to go slow and ask for a lot of help. That being said, I hear so often that these engines are easy...basic...nothing to it.
So, would you recommend I go for it and help take things apart, etc...for a guy that's willing to learn, can I do it? And if I do, how much $ do you think I could save?
I look forward to your input!
That will give you an idea of what is involved.
If you did it yourself, you would save the cost of the labor which is (I'm guessing) maybe 1/2 to 2/3 the price of a rebuild. So an average rebuild from someone else might run $4K so you might be able to do it yourself for $1500 or so. One question would be: what tools do you have or have access to...
If I'm way off, someone please correct me. I don't know rates anymore or how desperate builders are...
To paint the engine, plan on spending another $10 for two cans of high temp paint.
and that part is entirely different than the engine. Also I agree with the above concensus in that a knowledgeable person to help you out will be a great value. This forum is also a great resource. And above all else a little common sense goes a long way...ltlevil
In the end your going to save the labor cost to assemble the engine, which from a reputable shop should only be maybe 4-6 hours, and on top of that, you don't get any kind of warranty when assembling it yourself. Sometimes it doesn't make sense to do things yourself.
I've spent over $5000 so far and still don't have all the parts to put my motor back together. So far I have the crank, heads, intake, carb, pistons, rings, pushrods, cam, lifters, timing gear/chain, balancer, bolts, seals and gaskets. Still missing rods, bearings, distributor, headers, and all the little items needed to make it run.
As for cleaning and painting the block, count on spending a couple of hundred on the hot tanking service, cleaning supplies and paint. Should machine work be needed well, that requires digging a little deeper.
Staying within the $1500 range requires a lot of self control on new parts, reusing good old parts and a little scrounging at the swap meets.
I'm not trying to discourage you from building your motor, but rather offering a little reality to what it can cost. Try making a list of all the parts needed to assemble your motor, price out the all the parts and then determine what you can reuse and what you need to buy.
Good luck
By the way, it sure is nice seeing the brown truck arrive.
If you have some experience, I did an in car engine rebuild - replaced pretty much everything but the short block in about two years. The cost is almost impossible to determine because there are so many different options for almost every part. Think I have about 4K in the rebuild. Good luck.
But think, you'll know how to build an engine. So what if you don't get a warranty, then you just get more experience fixing something if you screwed it up.
And you know engineering, so you know how to troubleshoot. Plus, everyone here would help you. Have a forum member come help. Read all your books and ask more questions.
So really whats the amount of money you're saving? Well maybe a couple grand to do it by yourself, AND you now know everything there is about your small block.
http://store.summitracing.com/partde...0&autoview=sku
http://www.crateenginedepot.com/stor...2609-P4C2.aspx
This is cheap insurance!!! If you motor goes "POP" and throw's a rod you could loose your Numbers # engine
Drop this bad boy in and restore your #'s matching engine to factory specs while you enjoy driving your car
Go for it!
Its an easy job,well worth the effort! Saying i built the engine myself adds inches to a puffed out chest and impresses the younger folks. In my opinion,one of the most important factors, in a home rebuild,is cam break-in.
Be very,very careful in that area.
Here's my suggestion, which will let you get your hands dirty without exceeding your capabilities....
1/ Get a basic chev corvette service manual... such as a Haynes, and read through it. It will give you a rundown on the procedures required to rebuild/replace a lot of components on your vette.
2/ Remove your numbers matching engine and store it in the shed.
3/ Then buy a complete running, brand new, turnkey crate engine which will let you enjoy driving the car. It will start first go, be reliable, provide much more performance, and have a warranty.
Get a motor with the power you want, not a motor that only half serves your real lust for performance.... after all, be honest, why did you buy a Corvette rather than a Miata.
If you want to maintain true historic integrity, it will cost you a lot more, and provide less grins. You've got the original motor in a safe place when it comes to sell the car, so don't worry about losing value.
You could do the engine swap yourself, which is a good way to learn some basics without putting yourself in the deep end.
Then if you find you've got some time up your sleeve in the future, rebuild the original engine at your leisure, whilst still having a hard running reliable vette on the road!
cheers
