CS144 alternator upgrade
Old Jun 27, 2007 | 06:34 PM
lil_red_devil's Avatar
lil_red_devil
Default CS144 alternator upgrade
Hi guys,
Finally got myself into gear and started my upgrade. Have a question though, can I leave the additional charge wire attached at the alternator and starter in addition to running a new 170amp charge wire? Or do I need to disconnect them and cut them back?
Also I have chased the loom back and found that the red charge wire is soldered together with the red plug wire for the alternator connection. I have checked this on another vette and it is exactly the same. I am assuming that red goes to red and the brown wire goes to the yellow on the cs144 adapter plug.
Thanks for any help
Old Jun 27, 2007 | 07:51 PM
Durango_Boy's Avatar
Durango_Boy
The only extra wiring you need to do is add a run of 10 or 8 gauge wire from the BAT terminal on the alt to either the starter BAT terminal or the POS battery terminal.
Old Jun 27, 2007 | 08:26 PM
onaqwst's Avatar
onaqwst
i upgraded my alt wire to a 4 gauge and my ground to a 1odd....my question is can i just run a jump wire from the alt to the starter to feed the hott to the starter?......or will i fry something...... or should i just run another 4 gauge from the starter to the batt....
b
Old Jun 27, 2007 | 09:18 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
b
Stock battery cable is 0 gauge. You'd be downgrading.
Old Jun 27, 2007 | 10:37 PM
onaqwst's Avatar
onaqwst
really...0.... wtf... on the battery jump wire i bought a few years ago was a 4 gauge wire.....
seems like its the same gauge...4gauge.....hmmm... i'll check tomorrow....
thanks for the heads up though
b
Old Jun 27, 2007 | 10:42 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
b
No prob. My original cable was that copper-plated aluminum garbage in 0 gauge. The AC Delco replacement in real copper was a touch thinner...somewhere between 0 and 1.
Old Jun 27, 2007 | 11:25 PM
onaqwst's Avatar
onaqwst
u think running the 4 gauge for the alt is tooo big.... i have a tough audio system so i'm upgrading the wiring/etc....
b
Old Jun 28, 2007 | 02:09 AM
Z-man's Avatar
Z-man
If you don't have a GEN light, you'll have to add a resistor in the L terminal line (don't know what year your Vette is). Here's how I did mine: CS144 Installation
I left my original charge wire in place. No reason to remove it really.
Last edited by Z-man; Jun 28, 2007 at 02:14 AM. Reason: Edited for clarity and addition of flowery language
Old Jun 28, 2007 | 03:37 AM
lil_red_devil
My concern was if I left it connected both ends in addition to running the new high power charge wire that the old one would burn out. I have the gen light on mine (79) so dont need the resistors. Nice job btw
Am I right in saying then that everything can stay as it was on the old alternator (old charge wire + plug connector) and just run the new heavy gauge wire from the BAT to starter?
Old Jun 28, 2007 | 06:43 AM
Durango_Boy
The old SI plug can stay so long as you have an adapter. The SI plug won't fit the CS144. A lot of people snip off the SI plug and solder and shrink wrap a new pigtail from Autozone.
Old Jun 28, 2007 | 07:49 AM
lil_red_devil
Hi DB
I have a pigtail that I will cut and solder on. My main concern was the original charge wire. I wanted to leave it connected in addition to the new one as it runs into the back of the fuse box then out again but I don't know where! I didn't want to leave it off and kill power to anything that needs it and picks it up from there. I don't want to start frying things if it shouldn't be on though either.
wish i never started now... a snapped bolt in the head from alternator bracket took ages to get out and now the belt is too short! all part of the fun i guess. Cant wait to have her back on the road
Old Jun 28, 2007 | 08:06 AM
Durango_Boy
You can leave every wire that was hooked up before in it's place. You can even transfer over the ground if there is one bolted to the case. The ONLY thing you HAVE to do is convert that SI plug to a CS plug somehow and it seems you are doing that.
Old Jun 28, 2007 | 11:16 AM
Z-man's Avatar
Z-man
Yes - putting two wires (the original and a new one) between two locations is basically just adding more capacity to the same path (which is needed for higher amperage).
While you are getting the correct belt, you might as well add a new suspension and drive-train.
Old Jun 28, 2007 | 12:05 PM
shafrs3's Avatar
shafrs3
This drawing is a simplified depiction of the 1972 charging circuit. The power path to the fuse block is from a tap off of the horn relay labeled "existing loads", specifically the one with the 16 ga fusible link. This horn relay lug is the central distribution point for all power loads, any additional loads should be tapped off this same point, not from the starter.
The main point here is that the charging circuit doesn't travel "through" the fuse block, it has a dedicated path.
I don't know what year Vette you have but it should be wired similarly.
Old Jun 28, 2007 | 06:58 PM
onaqwst's Avatar
onaqwst
if that horn relay is just a 4 way plastic plug connector then make sure those connections are clean...... mine melted due to my headers and caused a bunch of other things.......
b
Old Jun 28, 2007 | 07:05 PM
lil_red_devil
Hi guys,
Mine is a 1979, therefore no horn relay distribution point
To CS144 alternator upgrade
