Help- Sparkplug broke off in head!
Old Jun 27, 2007 | 07:55 PM
73C34me's Avatar
73C34me
Default Help- Sparkplug broke off in head!
Helping a neighbor change plugs in his dodge v-10. Plug broke off at the top of threads to the porcelin area. The porcelin did not break off, but the hex head off the plug broke off, leaving the thread barrel & ground strap in the head, while the porcelin slipped free & is out, with the hex head attached. Strangest thing I have seen.
Currently I have been soaking the thread in PB rust buster & have inserted an ez out in to the threaded barrel. The ez out is grabbing & holding but I am afraid that the torque required to break it free would break the ez out first. I would guestimate that i have placed 60-70 ft. lbs. of torque on my breaker bar trying to loosen, with no luck.
My O2 is empty on my torches, so tomorrow I will fill the tank & place some heat. Any ideas or common experience? thanx
Old Jun 27, 2007 | 08:04 PM
Durango_Boy's Avatar
Durango_Boy
Heat and penetrants are your best bet. Obviously avoiding drilling until you have no other choice. Maybe a few well placed and specific blows with a tack hammer to the head casting surrounding the plug bottom to break any rust or corrosion bonds.
Old Jun 27, 2007 | 08:15 PM
Duke94's Avatar
Duke94
Aluminum head or iron?
Old Jun 27, 2007 | 08:16 PM
rabiddawg's Avatar
rabiddawg
im betting they were bosch plugs.
happened to me
got the sucker out using a pair of needle nose vise grips.
otherwise last resort would be to weld a bolt to it and go from there.
ez out could work if you got the biggest one you can fit in the hole.
Old Jun 27, 2007 | 08:28 PM
labguy6101's Avatar
labguy6101
3rd Gear
WOW thats weird! they probably didnt put any no-seiz on the threds when they installed it in the aluminum heads heat may help but unfortunatly the best way is to pull the head and remove the plug as you may have some chunks down in the cylinder. Sucks to be U good luck!
Old Jun 27, 2007 | 10:25 PM
73C34me's Avatar
73C34me
iron heads. will try heat & more penetrate with ez out tomorrow. will post findings. don't want to remove the head on this v-10 mopar.
Old Jun 27, 2007 | 10:35 PM
gullick65wi's Avatar
gullick65wi
One problem with EZ-Outs is that they might push the metal outwards when you're using them. This can be a problem on thinner walled stuff.
Old Jun 27, 2007 | 10:39 PM
...Roger...'s Avatar
...Roger...
Sounds like you have an open hole down inside the cylinder.If this is correct you can trim a hack saw blade to go down through the hole.Take a hammer and remove the pitch from the teeth to make the blade thinner.Make 3 slices through the spark plug just into the threads.With a small chisel and a magnet tap each piece away from head threads.This will leave the 3 small scores in the threads in the head-shouldnt hurt since the taper does the sealing.
Old Jun 28, 2007 | 12:26 AM
ltlevil's Avatar
ltlevil
A little "tool" we use to use in the machine shop was a tap that had been ground to the shape of a square and slightly tapered (4 sharp edges). The size needs to be just big enough that you can't push it all the way through the threads and can tap it in with a hammer (small) to engage the sides of the remaining threads. This will dig into the sides without pushing outward like the EZ out.
ltlevil
Old Jul 1, 2007 | 08:50 AM
73C34me's Avatar
73C34me
Successfully removed the thread barrel of the spark plug from the head!! Used a medium sized welding tip & applied heat (a fair amount) & was able to turn the thread out with the ez out. When it was removed, it was evident that it twisted & snapped off right below the hex head as thought.
Old Jul 1, 2007 | 09:13 AM
Durango_Boy
Does it look like it was cross threaded when it was installed?
Old Jul 1, 2007 | 09:45 AM
Roadster71's Avatar
Roadster71
Just recently went thru the same thing with my 1999 Dodge Dakota. Save your self the aggrevation ,remove the head and send it to the machine shop. I tried everything else to no avail.
Old Jul 1, 2007 | 09:52 AM
dalewilson99's Avatar
dalewilson99
Had the same thing happen on my daily driver, a 1986 Mazda pu. I took the poor little truck over to a buddy who restores very old industrial tractors, he welded a bolt into the remaining part of the thread and turned the thread out.
Dale
Old Jul 1, 2007 | 11:47 AM
moosie982's Avatar
moosie982
Same crap happened to my last Honey's car a '94 Fleetwood Cadillac (LT 1) and almost ruined our upcoming vacation, I had to rent a car , sprayed the hell out of it with penetrant before we left and when we got home sprayed it some more untill I was calm enough to get it out, soaking and being honked off at it, it literally fell out when I used a large by large eezzee out. It was caused by the extended intervals that the later model cars specify for normal maintainence . It was an A.C. plug. I spent most of the vacation thinking about how in the hell I was gonna get the broken plug out. That sucked, but managed to have a decent time anyway,,,,Peace,,,Moosie
Old Jul 1, 2007 | 01:30 PM
ltlevil's Avatar
ltlevil
Glad to hear you got everything worked out.
ltlevil
Old Jul 1, 2007 | 11:46 PM
73C34me's Avatar
73C34me
there was no thread damage, as the new plug threaded in as one would expect. I did state that the new plugs had to have anti-seize on them. I think that they were the orignal plugs... left in too long.
To Help- Sparkplug broke off in head!
