Speed warning install
Old Jun 28, 2007 | 12:46 AM
2kbluer6's Avatar
2kbluer6
Default Speed warning install
I'm embarassed to even ask this. Looked through my factory shop manual, didn't find anything. Tried searching, but I still can't find the answer. Where on the back of the speedometer does the white connector for the speed warning sensor plug in? Thanks.
Old Jun 28, 2007 | 02:22 AM
Z-man's Avatar
Z-man
What is a speed warning??
Old Jun 28, 2007 | 09:53 AM
2kbluer6's Avatar
2kbluer6
RPO U15 - Speed Warning Indicator $11.60
Basically, you set a certain speed on your speedo (yellow needle) and when you reached that speed, a buzzer sounded. It was only available on the 67-69 model years.
Old Jun 28, 2007 | 10:31 AM
T-TOP TOM's Avatar
T-TOP TOM
It plugs in the speed warning buzzer which is attached to the back of the speedometer head. The buzzer is 1 3/4" long, by 7/8" thick, by 1 1/16", with a 1/16" mounting mounting plate with two screws attaching it to the back of the speedo head on the left side, (looking at the front of it) betweeen the two light socket holes stamped with "gray" marking above each socket on my 68 unit. Good luck, Tom
Old Jun 28, 2007 | 11:06 AM
Z-man's Avatar
Z-man
Interesting. As long as I've been around Vettes, I've never noticed those. I would have guessed that kind of "feature" would have been included on the same cars that had the 85mph speedos (late 70s & early '80s) - during the days when the speed ***** ruled the earth.
Old Jun 28, 2007 | 11:24 AM
2kbluer6's Avatar
2kbluer6
Thanks!
Old Jul 26, 2007 | 06:33 PM
2kbluer6's Avatar
2kbluer6
Do you (or anybody else for that matter) have a picture of this connection? Thought I'd resurrect the thread because I still cannot locate this part.
Old Jul 26, 2007 | 09:23 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
first year was '80.... luckily, it can be changed.
Old Jul 27, 2007 | 03:19 AM
GunPowder's Avatar
GunPowder
@2kbluer6: I also have installed the speed warning option in my 69. I have currently disassembled my dashboard and all related components. Since I am not allowed to post pictures in the forum I could send you these via email (if you send me your email address per pn).
To Speed warning install
