Matching Engine Numbers
Old Jun 28, 2007 | 03:05 PM
71Vince's Avatar
71Vince
Default Matching Engine Numbers
I recently purchase a 71 Vette that I believed to be a number matching car since the vin# numbers matched the partial vin# on the engine pad. When I looked at the block suffix code I noted the suffix to be CKX which is a 72 block according to all the literature.
Does anyone know if there was an exception to suffix block code in 71 or did I purchase a car with a re-stamp vin# on the engine block pad?
Old Jun 28, 2007 | 03:14 PM
71Vince's Avatar
71Vince
Engine - LT1?
Old Jun 28, 2007 | 03:32 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
According to the NCRS, CKX is indeed a 1972 350 base engine. There's a chance that the car had a bad lump which may have been replaced by the dealer under warranty, but unfortunately there are people out there who re-stamp blocks, and it's all too possible you could have one. (For instance, there are more L88's today than the factory ever turned out.) If you're lucky, with a little detective work you may find the original owner who could shed light on this mystery for your.
Old Jun 28, 2007 | 04:08 PM
Red70vette's Avatar
Red70vette
You are correct. No 71 code CKX. Hopefully your eyes need help and it is really CPX which is the only 71 code with an X in it and it is a 454 LS6 425 HP engine.
If not join the club you have been misled. It is a restamp and not a good one. You can also check the casting dates on the block and the heads to see when they were manufactured and compare that to the build date on the car. You can't build an engine after the car and expect to call it original or numbers matching.
I would suggest you contact the seller and tell him what you think.
Old Jun 28, 2007 | 04:52 PM
Carl Granquist's Avatar
Carl Granquist
Any chance you could post a picture, or add a little something to your profile? It would help us help you.
On my '71 I also verified the code numbers/letters stamped on the alternator and carburator, plus there are some casting numbers on the Muncie and the rear differential.
There's a casting number behind number 7 cylinder on the housing that should indicate block type. Won't positively ID for the year but will confirm you're in the ballpark. Mine's 3970010 so it covers 12 years of small block chevys with various horsepower ratings.
Good luck.
Old Jun 28, 2007 | 06:03 PM
PRNDL's Avatar
PRNDL
What is your vin? What trans do you have? The engine suffix CKX tells me you have a base engine 72 with automatic trans. What do you think you have?
Old Jun 28, 2007 | 09:24 PM
71Vince's Avatar
71Vince
The Vette has a 350 with an automatic 400 transmission. I guess I need to look at the engine date to determine if the engine pad has a re-stamped VIN # on it.
Thanks for your advice!
Old Jun 28, 2007 | 11:16 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Look at the rear of the engine block on the top pass side near the bellhousing. There will be a casting date code there that tells when the block was cast. If it was after the car build date you were scammed. There were some instances of very late build date cars with suffix codes of the following year. I had this happen with a 65 rear end that had a 66 suffix code (ratio code) and a late 65 model year assembly date.
Old Jun 28, 2007 | 11:33 PM
TheSkunkWorks
Just in case, what's your VIN#? Maybe there's a chance you really have a '72, and you OK.
To Matching Engine Numbers
