transmission questions
Old Jun 29, 2007 | 10:57 PM
AWilson's Avatar
AWilson
Default transmission questions
My 68 was built with a 327 350hp engine and a M-21 close ratio transmission, and a posi 370R rear end code: 02G81NA
I think it is the actual tranny because it has a casting number 3885010, date stamp is P0921. I think thats Sept 21 of probably 67 as my car was built in Oct. 67.
Basic Questions:
Is this a good combination and if so what is it best for? Off the line?
What is it bad at? Highway driving?
I assume I will have to shift through the gears faster because it is a close ratio?
Will it be more difficult to get rolling?
Sorry for the basic questions but, well, I don't know much about transmissions!
Old Jun 30, 2007 | 08:12 PM
DrainSurgeon77's Avatar
DrainSurgeon77
The trans was built sept. 21st 1965 for a 1966 model year car...
3885010 main case was used 1966-67 model years...
3925660 main case was used 1968-69 and beginning of 1970... Crash
Old Jun 30, 2007 | 09:49 PM
birdsmith's Avatar
birdsmith
Since all four-speed transmissions are direct (1:1) in fourth gear, a 'close-ratio' box by definition would would have a 'taller' (numerically less) first, second, and third gear. If your box has M21 internals to go with its M21 case then it would have closer ratios than the comparably wide-ratio M20. Compared with the wider-spread M20 ratios you would have to shift the M21 more often (better for twisty roads and racing) but would have to slip the clutch more getting away from a stop and would have less pulling power in first. If you're going to use your car as a cruiser rather than a racer an M20 would be the better way to go, but then again once you're in fourth gear they're all the same.
Old Jul 1, 2007 | 06:35 AM
AWilson's Avatar
AWilson
Crash - Thanks for the info but what reference did you use? I can't find this in either the Corvette Black Book or NCRS Judging Guide. From what I have gathered, they didn't mark the year codes until 68.
Old Jul 1, 2007 | 06:43 AM
AWilson's Avatar
AWilson
Thanks birdsmith, so what your saying is, for best accelleration from a standing start the M-20 is best, and since they all end up at 1:1, highway driving is all the same, right?
Old Jul 1, 2007 | 10:38 AM
birdsmith's Avatar
birdsmith
Yessir- for a daily cruiser/driver the M20 is probably a better way to go.
Old Jul 5, 2007 | 06:14 PM
DrainSurgeon77
Muncie started year codes in 1967, before that you had to use casting numbers and P number location to determine model year...
I've been building Muncie and Borg-Warner 4-speeds for over 20 years, along with Doug-Nash/Richmond 5-6 speeds... Crash
To transmission questions
