81 Dash removal and knobs
Old Jun 30, 2007 | 08:19 PM
Plane_guy's Avatar
Plane_guy
Default 81 Dash removal and *****
Looking at the assembly manual, am I correct to say that there are only 4 screws holding the dash in? Also, do I have to remove in the instrument cluster to get it out?
Second ?
How do I get the lock assembly off the glove box door?
Third? Does the headlight **** just pull off?
I'm trying to re-dye all my parts and thought is would be easier to strip stuff off to make it easier. Also, I need to repair Bubba handy work on the heat controls.
Old Jun 30, 2007 | 08:38 PM
SIXFOOTER's Avatar
SIXFOOTER
I think there are more than that, but not a lot more for the dash itself
Yes you do
Second ?
I think there is a clip on the inside of the glove box, I'll have to look
There is a very small button on the back of the switch, push it in and the **** and the stem will pull out
Removing everything is the way to go, you will need to get some wax/silicone remover and clean everything VERY well fir the dye to stick
Grrrr, editors...
Old Jun 30, 2007 | 08:41 PM
Big2Bird's Avatar
Big2Bird
Might I add. When you pull out your 25 year old dash, chances are it is going to carck into 50 pieces,
Old Jun 30, 2007 | 08:43 PM
Plane_guy's Avatar
Plane_guy
I hope not
Old Jun 30, 2007 | 09:34 PM
SIXFOOTER's Avatar
SIXFOOTER
Be carefull with the ends, they will try to break off
Old Jun 30, 2007 | 11:45 PM
Plane_guy's Avatar
Plane_guy
Well, after cleaning the silicone from around the lock, remove the epoxed finishing nail, I still can not figure out how it comes apart. I found a picture of an assembly on ebay and it appears something on the end holds it togther. The **** and center cylinder are one unit so it goes the full length of the assembly. I'm giving up tonight and try again tomorrow
I love how Bubba even had his hands on something so simple as a glove box!!
Old Jul 1, 2007 | 12:14 AM
JLinCA's Avatar
JLinCA
Definitely watch the upper ends of the dashboard when you take it out, they will crack on top if bent. The rest of it will come out just fine, just take your time. I had no troubles taking mine out or putting it back in. The painting on mine came out excellent, just prep properly like sixfooter said.
That box lock is nothing but a pain in the azz. It's just one of those things you have to mess with till you get it.
Old Jul 1, 2007 | 10:35 PM
Plane_guy's Avatar
Plane_guy
Okay, I figured out the lock!!! All it takes a small flat bladed screw driver. Looking at the lock with the latch facing up, there is a small opening. In there you should see a silver tab sticking up from the inner cylinder. With the screw driver push that down, it's spring loaded. As you push, pull on the ****. It should slide out just an 1/8 of an inch until you hit another bronze colored tab. That would be the first tumbler piece. Do the same for that and the rest of the tumblers (4).
Here are some pictures.
Looks like some just forced these out since they are bent pretty bad. But they still work get and I will leave them as is.
Old Jul 2, 2007 | 12:02 AM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
If you already have the dash off, ignore this.
There are two screws in each door jam. There are two clips attached to the underside of the dash. One above the glove box and the other above the speedo cluster. Each has one small bolt holding it in place. After you get the dash out, attach the clips back to the dash. They are meant to be on the dash when it is installed because they clip on to two brackets that stick out from below the windshield.
If you don't drop the steering column to remove the dash, take the steering wheel off. I've had mine off both times I've removed the dash and it makes it very easy. Besides, removing the steering wheel is less work than dropping the column.
Old Jul 2, 2007 | 07:22 AM
Plane_guy's Avatar
Plane_guy
I still haven't decided if I'm going to pull the dash?!?!? If I feel like I can get it sprayed in the car, I'll probably leave it there.
I tried to mask it off yesterday, but my tape would not stick? Do I use plan old masking tape or is there something else I should look for. I tried this after wiping down the dash with cleaner and still no luck?
Thanks for the tip on the column! Looking at it yesterday, I thought it would be easier to get it out of the way.
To 81 Dash removal and knobs
