Engine Torque vs Gearbox Torque
Old Jul 2, 2007 | 01:28 PM
AkXb70's Avatar
AkXb70
Default Engine Torque vs Gearbox Torque
Whats the difference?
GM rates thier current lineup of hydramatics for both engine torque and gearbox torque, with gearbox torque being MUCH higher than engine torque specs.
For example:
4L70:
400 ft/lbs ET
670 ft/lbs GT
4L85:
460 ft/lbs ET
885 ft/lbs GT
6L80
439 ft/lbs ET
664 ft/lbs GT
Sometimes GM puts engines in front of transmissions that exceed the max engine torque #'s but are still well under the max gearbox torque numbers. The 4T65 is a good example imo. Rated at 280 ET / 400 GT, the engine is both in front of the 280 ft/lbs 3.8L s/c engine and the 5.3L LS4 wich puts out 315 ft/lbs torque IIRC.
My guess would be engine torque is the max the transmission is typically used with while the gearbox torque is the max the transmission can physically handle? Or am I completely missing the point? If I'm right, that 4L70 would be lovely for the C3
BTW, all these numbers are direct from GM's site.
Old Jul 2, 2007 | 01:36 PM
S489's Avatar
S489
i really have no idea, but those GT numbers look they are in the range of torque multiplication of a torque converter. maybe the GT values are multiplied by the TC and then reduced by gear losses . . . ??? . . . just guessing
Old Jul 2, 2007 | 04:17 PM
AkXb70's Avatar
AkXb70
Torque multiplication really goes up that high with a TC?? I thought it was only a few percent.
Old Jul 2, 2007 | 04:33 PM
S489's Avatar
S489
the last one i ordered was close to 1.9X (Max)
the efficiency, would be nice to be 100%, but better ones are in the high 90's%
Old Jul 2, 2007 | 05:41 PM
gerry72's Avatar
gerry72
Converter normally does 2.0 - 2.5 multiplication...for the first few feet off the line.
Old Jul 2, 2007 | 05:49 PM
AkXb70's Avatar
AkXb70
So theoretically, could you run a higher torque engine than specced with a low multiplication converter and still be in the 'safe zone' as long as you stayed under max GT? How would you determine the mutiplication of a TC (higher stall speeds = higher multipliers)?
I wont be doing this, but this is pretty interesting since I was under the impression that TC's didnt increase torque THAT much. I have a LOT to learn about transmissions
Old Jul 2, 2007 | 06:24 PM
gerry72's Avatar
gerry72
Manufacturer should tell you what the multiplication ratio is since it depends on the turbine and stator that they use. This multiplication is why it's called a torque converter instead of a fluid clutch. Early automatics, like the Dynaflow, used a fluid clutch and a four-speed automatic. The 1st gear was extra low since the coupling didn't multiply torque.
Old Jul 3, 2007 | 08:50 AM
S489's Avatar
S489
but - don't always believe everything the mfg tell's you on torque multiplication!
see this:
http://www.converter.com/torqueratio.htm
"They (compertitors) also advertise STR’s (STALL TORQUE RATIO) of 2.7, 2.9, 3.0, 3.2, etc. this is pure BS."
"The formula for STR is EXACT OUTPUT TORQUE ÷ EXACT INPUT TORQUE = STR. This requires a known power source and a data recovery system."
"...the stock torque converter you took out of your car has a STR of 1.9-1.94"
To Engine Torque vs Gearbox Torque
