Pulled the trigger on the 408...
Any thoughts or proven recipes?
The 400 is a huge small block,so you've got to upsize some of the parts to get some power out of it. If you put the RPM heads on,and a mild cam it will make a great tow truck engine,but I don't think that's the direction you really want to go.
Should I go forged everything with Brodix/Dart heads or would this level of hp keep breaking the car in other areas?
I don't know how much you have into it so far but here's what you are looking at if you want over 500 HP:
$1400 for heads (complete with rocker arms and stud girdles)
$500 for Eagle forged crank (I'd really recommend a forged one)
$350 for forged pistons
$430 for Eagle h-beam rods
$50 for pushrods (yes, you can get .080 wall 5/16 pushrods for that little)
$400 for a nice solid or hydraulic roller cam & lifters
$30 High volume oil pump
So, you are looking at about $3000 - $3500 for plus what you'll pay for machine work..
I don't know how much machine work you need but you could be able to stay under $4k for the complete build and make 550+ HP on pump gas...
Just make sure that you are running solid spicer u-joints..
RHS heads are the way to go if you want inexpensive power..
I'd go forged if you want power and durability.. The Eagle stuff is good and cheap..
http://www.racingjunk.com/post/83126...-FOR-SBC-.html
I have no personal experience with the seller but he has been on Racingjunk for a while..
I took a detour,tried the 700r4,learned my lesson,and now run a th400. In all this,the stock rear and half shafts haven't given me a lick of trouble.
Heads up. You WILL have to upgrade the radiator,and most likely the fuel pump/carb. A 400 that makes a lot of power gets hot,and thirsty!
My SCAT cast 9000 crank has seen 7000 rpms many times,and with no issues. I would say forged is good insurance,but probably not needed if your shooting for around 500 hp or so.I just used ARP fasteners,and checked all the tolerances carefully.(hand filed ring gaps,checked cam/rods,hand port matched the intake to the heads...etc.)
If you're looking for the magic combination,I can only tell you what I've tried ,and liked. Everyone has there own idea of what the perfect combination is,so even if you built my 406,YOU may feel it's too aggressive.Some may think I should have gone wilder with the cam,and cranked up the compression a point or two. I like yourself wanted as much as possible without going too far. I'm at 254 degrees @.050 and though it's a lumpy idle,it's not too bad. I wouldn't recommend going any bigger if you plan on keeping the car on the street. As it is,I sometimes loose power brakes,and idling at the stop lights forces me to shift into neutral so I can blip the throttle to keep it from stalling if I sit there too long.
My previous combination ran the RPM intake,and Comp XE-284 cam with 1.60 rockers. Much better street manners,but still potent.When I bent two pushrods turning 6500 rpms,I decided to anti up,and go solid.
GrandSport is dead on with the pricing. I spent about $4500 or so for mine with AFR heads,machine work and all.I did the assembly at home and saved big time though.
http://chevyhiperformance.com/techar.../148_0306_406/
and this one where they upgraded the above combo
http://www.chevyhiperformance.com/te...imp/index.html
Read those thoroughly several times ... very good info ... not etched in stone ... little is ... so use 'em as a guideline. Whatever you do should depend on ... first, what your budget $ is ... second, what you'll actually need the motor to do.
cosider a 200 runner head still give you good torque allow your
engine to breath some.
30 30 cam
10.95 cr
400 std block
dual 500 Preformer carbs
All very streetable with 3.55s and M-20.
Maybe I should just stick with my original plan of a 383 with the Edelbrock RPM Package.
