More interesting
Old Jul 2, 2007 | 06:53 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default More interesting
So I have been comparing cams
It appears a hyd. Flat tappet cam has an RPM range of 4200 RPM according to Comp cams
Solid Flat tappet cams have a range of 4400 rpm
Both the solid roller and the hyd. Roller have a range of 4000(though the hyd. rollers fall off the higher the RPM band, I think my hydrarev kit will do something about that.
Old Jul 2, 2007 | 07:53 PM
Little Mouse's Avatar
Little Mouse
I would say the flat tappit cams are an exaggeration the rollers will have a wider power band.
