C3 (1979) Brake Problem
Old Jul 3, 2007 | 05:45 AM
Paul L's Avatar
Paul L
Default C3 (1979) Brake Problem
Can anyone explain this brake problem on a 1979?
I had noticed last Sunday that I thought my brakes seemed a bit spongy? Today the same thing happened so I made it home probably just in time. While I backed in the laneway there appeared to be little or no brakes. The dash brake light came on momentarily. Pumping the brakes restores pedal pressure again. From the shop manual it seems it could be air or the proportional valve for the front and rear systems. Strange, as the master cylinder reservoir level is very close to the top?
And later...
This afternoon I replaced the hoses leading from the carb outlet pipe to the power booster. One clamp was broken, it looked good but the screw tightening system didn’t engage. It must have been like that forever. The other clamps were all fairly loose, but I didn’t see any breaks in the hoses. I reassembled everything and started the car. Pumping the brakes I got equal resistance each time, then again I didn’t take it out of the laneway or put it in gear. The pedal travel could be normal, I’m not sure as I’m a bit paranoid now? The pedal does not go near the floor like when I backed into the laneway yesterday.
Following the GM manual, when the car is off, and after pumping the brakes more than three times to remove vacuum, there should be no more than 1.8” travel. Following this procedure the pedal had lots of resistance, more than when running, and there was 1.125” travel. There is no fluid on the ground, and a quick look at the calipers doesn’t indicate any leakage. The reservoir as mentioned is near the top. . So I don’t know what to think?
Old Jul 3, 2007 | 08:50 AM
79L48's Avatar
79L48
You could simply have low fluid. Open the master cyl and check it for level. Every bit as likely, your system has air in it from leaking caliper seals. You may not see fluid leaking out, but they are notorious for air and moisture bypassing the seals and undermining the breaks.
Bleed the brakes using new DOT 4 fluid with silicon which is resistant to moisture. Make sure you bleed all the old fluid through the system. Start bleeding with the rear pass side caliper (farthest away from the master cyl). Make sure you bleed both bleeders on each caliper. do not allow the master to get empty. Have a friend or two help you, or buy a power bleeder/bottle combo to keep new fluid running through the system. Bleeding the brakes is tricky on these cars because of the caliper design. You can't overbleed your brakes. Good luck!
Old Jul 3, 2007 | 09:13 AM
dennis's Avatar
dennis
And later...
sounds like classic air pumping.
Are your calipers original?
Or ,at least, do they have original type seals?
Have you resurfaced your rotors lately?
If yes to any of these questions, do yourself a favor and get a set of "O" ring seals. The kits are carried by any number of venders.
There's a lengthy explanation as to why the originals would pump air. If your intetrested in the cause do a search here or at the NCRStech board.
stingr69's Avatar
stingr69
Master cylinder may be shot. No fluid loss and a mismatched front to rear balance. Maybe the master is having difficulty maintaining equal pressure because the fluid is bypassing the middle piston. If the M/C is old you may need to replace it.
Thats my guess anyway.
-Mark.
Old Jul 3, 2007 | 09:22 AM
red topless gator's Avatar
red topless gator
And later...
Had the same exact problem with my 79 a few weeks ago. It was hard to spot, but found the right front caliper leaking (original), put in rebuilt one and good as new..........LT
Old Jul 3, 2007 | 11:19 AM
Paul L's Avatar
Paul L
It's my brother's car. I sold it to him in 2003 when I bought the 1967.
I just tried the car in his driveway. Pedal is pretty firm and high with the engine off. With engine on the pedal is low; I would say 1" from the carpet. Not good. That can be pumped up another inch or so to what I remember as "normal".
-SS calipers are about 15 years old so seals are suspect
-front rubber hoses are 9 years old; being alone I could not see if they were swelling under pedal pressure
-pads are organic with about 25,000 miles (perhaps past service life?)
-master cylinder (MC) is original 1979
-master cylinder reservoirs are down about 1/2" (due to pad wear?)
-fluid is DOT 5 (silicone)
It may be a combination of things. My inclination is to have it diagnosed by a professional (not me) rather than throwing time and parts at it. And make a decision as to who will do what with what parts. I don't mind re-doing one caliper with a $20 seal kit (if one is bad) but if one is gone the others will follow shortly. The master cylinder is a job I would not undertake.
Old Jul 3, 2007 | 11:32 AM
Matt Gruber's Avatar
Matt Gruber
make sure the "pro" has dot 5 experience; ask to see his tank of it.
the story "sounds" like the booster hose was loose. But i'm not sure.
Old Jul 3, 2007 | 12:27 PM
73 red vette's Avatar
73 red vette
Could you point me to some of the venders that carry these kits in the U S the only one I know of is VBP
TIA
Old Jul 3, 2007 | 01:02 PM
Paul L's Avatar
Paul L
He picked up a booster hose, check valve, and in-line filter today. We'll try it from the inexpensive end first.
Old Jul 3, 2007 | 01:14 PM
dennis's Avatar
dennis
TIA
Paragon reproductions
Bairs
Dr. Rebuild
Zip
I bought mine,(1995?), when the developer of the o-ring design sold direct. Zero Tolerance Inc.(ZTI). O-rings and aluminum pistons still working flawlessly, in my original, unsleeved calipers.
Was later sold to a company in Florida I believe. May have been VBP
Old Jul 3, 2007 | 01:47 PM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
I had thge same thing happen on my 79 no leaks just had to bleed them & I did it twice to make sure all the old fluid is gone. My problem went away
To C3 (1979) Brake Problem
