New Product Release
Old Jul 6, 2007 | 03:42 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Originally Posted by zwede
What about the famous 'glass spring bounce? Do you need special shocks to cure the bounce with these?
You always need to on fiberglass spring. The GR-2's are a good match.
Old Jul 6, 2007 | 06:40 PM
cortru's Avatar
cortru
How does the KYB Gas-A-Just shocks match up with this spring?
Old Jul 6, 2007 | 06:59 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
I'm using your control arms and 550# springs (1/2 coil cut off for lowering though) in front. This spring looks too soft for my car. Can you reccomend another if that's the case? I was eyeing 330# composites. I would like to match the shocks you sold me for the front, too.
Old Jul 9, 2007 | 09:36 AM
Van Steel's Avatar
Van Steel
The Gas-A-Just shocks are for steel springs only. The are not valved correctly and will not function as they are supposed too.
Old Jul 9, 2007 | 09:42 AM
Van Steel's Avatar
Van Steel
My 330# spring will be in today and ready to ship today. Same price as this lighter spring.
This 200# spring is like the stock 9 leaf.
Old Jul 9, 2007 | 10:59 AM
SanDiegoPaul
I've been driving for over a year with the factory rear setup, since putting in the new front end. What would I feel different between these two choices in springs? What shock do I need? I think you sold me a very stiff shock up front, if memory serves.
Old Jul 9, 2007 | 11:24 AM
Oldguard 7's Avatar
Oldguard 7
I will stay with the stock steel spring. It's been working for years and they are cheaper to replace than these composite springs.
Old Jul 9, 2007 | 11:27 AM
Van Steel's Avatar
Van Steel
You got Bilstein Sport shocks up front. The stiff ride is probably b/c you cut the stiffest springs for the vette which made the springs even more stiff. If you go to the 330# rear, you can go with Bilsteins.
The 330# is going to be stiffer than the 200# spring. Your ride won't be as cushy. You will have to use 8" bolts with the 330# spring.
