Rear Main Seal Install
Old Jul 8, 2007 | 05:56 PM
happiedazs's Avatar
happiedazs
Default Rear Main Seal Install
I have a 75 L-82 auto that drips a few drops of oil on the garage floor every time I take the car out for a spin. Everything is stock/original. I was thinking of replacing the oil pan gasket and the rear main seal. How difficult is it to replace the rear main seal and are there any tricks anyone can share (or warnings what not to do) to make the job go smoothly.
Old Jul 8, 2007 | 06:21 PM
ltlevil's Avatar
ltlevil
First of all make dead sure its the rear main and not a valve cover or oil sending unit dripping down the backof the block.
As far as the job goes for the rea main it just depends on how easy everything comes apart. Do yourself a huge favor and buy a one piece oilpan gasket to put it back together with. Also might not be a bad idea to change the oil pump but if you have good oil pressure now it may not be necessary. Also take the time to look in the bottom of the oil pan for any foreign material or "pasty" substances. Other than that follow the instructions in the shop manual and rear main seal. AND BE WARNED THERE IS A FRONT AND REAR SIDE TO THE REAR MAIN SEAL.
ltlevil
Old Jul 8, 2007 | 06:27 PM
Durango_Boy's Avatar
Durango_Boy
You'll have to drop the front suspension enough to get the pan down. Most just remove the two pitman arm bolts and lower that.
Drain and remove the pan. Clean it thoroughly and check to make sure it's square and level on a nice flat surface.
Remove the rear main cap, making sure you get the bearing with the cap so when it's reinstalled it's not out of place.
Gently and easily tap the cap half of the rear main seal out of the main, and replace it with a half of the fresh seal making sure you get the orientation correct.
Then, under the car, carefully tap the other half of the seal out from around the crank. Be VERY careful not to scar the main journal.
Lube the new seal up with some oil, and insert it. Once you get it started you will probably be able to push it up and around with just your fingers. Once it's close to fully inserted use the butt of a wooden handle to tap it into final position.
Reinstall your main cap, torquing the bolts to spec.
I would suggest buying a Fel Pro one piece rubber gasket. They are amazing;y easy to install and being that they are only one piece they make pan leaks a thing of the past.
Then reinstall the pan with the new gasket, torque the bolts to spec, and raise the suspension back up by reversing the pitman arm removal.
Finally, replace the oil filter, fill with oil, and start to test.
Old Jul 8, 2007 | 07:46 PM
SmokinBBC's Avatar
SmokinBBC
Originally Posted by Durango_boy
Reinstall your mail cap, torquing the bolts to spec.
Before reinstalling your cap, read the directions that came with your seal. Or look in your shop manual. There is a requirement for a small amount of sealer on the bearing cap ends before you put it back on. If you don't follow the instructions, it will leak again....just my .02.
Old Jul 8, 2007 | 07:57 PM
mbeeman350's Avatar
mbeeman350
St. Jude Donor '03-'05-'06-'07-'09
Just a note, before removing the pan put the timing mark on 5:00 to 6:00 O'clock. The counter weights on the crank will be out of the way, giving you more clearance. Making removing and installing the pan easier.
Just pulled the pan on my 72 chasing an elusive oil leak and I used the Fel Pro 1 piece gasket. I would never go back to the old syle 4 piece set up. There are 2 models for SBC, one is thick and on is thin. Use the thin for 74 and back a nd the thick for 75 and up on Gen1's. Makes instalation a snap. Especially when you are under the car...best of luck
Old Jul 8, 2007 | 08:45 PM
Durango_Boy
Good call Smokey. I always forget to mention it, even though it's int eh directions and is an important step.
Old Jul 8, 2007 | 08:52 PM
speedreed8's Avatar
speedreed8
i replaced the bearings and rear seal in my 79 L82 earlier this year, after replacing bearings, i tried to install the upper portion of rear seal. it was really tight, and wouldnt roll the rest of the way in, yes i oiled it.
i had to loosen the center and next to the rear main caps again to allow crank to drop just enough, and the seal went right in. watch that plastic coupling on oil pump drive shaft, its usually very brittle and breaks easily if it has alot of miles. one piece oil pan gasket is the way to go, so far no leaks. good luck
Old Jul 8, 2007 | 09:41 PM
coinwasher's Avatar
coinwasher
Good point on the plastic coupling, I like the metal ones better.
Old Jul 9, 2007 | 12:40 AM
happiedazs's Avatar
happiedazs
Many GOOD pointers --- thanks guys !!!
Old Jul 9, 2007 | 07:38 AM
Paul L's Avatar
Paul L
You will have to drop the front Y-pipe if you have factory exhaust with cat con. It can be a **** to get off.
Here are instructions re use of sealant.
As mentioned, there is a front and back to the seal. It can be installed backwards!
Old Jul 9, 2007 | 08:42 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Originally Posted by paul67
Looking at this picture, I'm soooooo glad that I'm using sidepipes on all my C3's..
I installed my new rear main seal when the engine was on the stand, so it was a lot easier.. Used a little RTV where the seal pieces connect. Made sure that the seal lip was pointing in the correct direction (based on the instructions) and that was about it.
Old Jul 9, 2007 | 08:55 AM
Paul L's Avatar
Paul L
At the time of that rear seal installation, the exhaust was relatively new and came off. But if the manifold studs snap this can turn into a miserable job.
Old Jul 9, 2007 | 11:32 AM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
I thought I needed a rear seal in my 78SA. When I dropped the pan and saw how compressed the gasket was I elected to just change the gasket. No more leak. A week later I did my white79, again just the gasket. Guess I was lucky. And my L82s used the thin pan end seals. All PoopBoys had in one piece was the thick one. No way that was going to work. Used the old fashioned gaskets with blue rtv. That blue rtv matches the Chevy blue perfectly.
To Rear Main Seal Install
