So, what is my engine...
Old Jul 3, 2007 | 09:09 PM
yel76low's Avatar
yel76low
Default So, what is my engine...
18D180990 TO603HN
Do those codes make sense? I was in a dark garage using a flashlight, so I might have mixed up a number or two... but the HN is definitely correct.
Can anyone tell me what this engine is from?
Thanks...
Old Jul 3, 2007 | 09:39 PM
Jc3vette's Avatar
Jc3vette
Look for the casting number. It is found on the bellhousing flange at the rear of the block. You will see large letters GM and below this will be the casting numbers. with this number it would be easy to tell what you have.
The numbers you provided I guess are most likely from the milled pad at the front of the deck surface, extending just past the cylinder head. these numbers can be changed or faked easily.
Old Jul 3, 2007 | 09:57 PM
FrankVincent's Avatar
FrankVincent
Account disabled by user request 5 Jan 09
Originally Posted by yel76low
18D180990 TO603HN
Thanks...
18D180990 = 1968 Atlanta Assembly Plant-Passenger Car-VIN:80,990
T0603HN = Tonawanda, June 3, 1968
HN codes were the following ....
1965 327 Corvette375 L-84 4-spd FI Rochester, HP solid cam
1968 327 Impala 250 L-73 Power glide 4-Brl Hyd Cam
1969 350 Impala 300 L-48 TH 350 4-Brl Hyd Cam
So it looks like a 1968 Impala 327, serial number 80,990, June 3 engine build date in Tonawanda ....
Per ...
Chevrolet by the Numbers, 1965-69, Alan Colvin ... and
http://www.chevymania.com/partsid/su...fm?block=Small
You can confirm this by posting the block casting number and casting date as found on the rear driver and passenger side ...
Old Jul 3, 2007 | 10:49 PM
yel76low's Avatar
yel76low
Oh, bubba....
So, what does that 250hp translate to in the new, net standard. How would this stack up against what should have been in a '76 L48?
Old Jul 3, 2007 | 11:22 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
Oh, bubba....
better than the 27 HP engine it came with.
more seriously, it's a small block 350. with enough dough and some time you can make some serious HP out of it.
Old Jul 3, 2007 | 11:29 PM
SEVNT6's Avatar
SEVNT6
I thought it was 127.................
Old Feb 9, 2008 | 10:30 AM
D.T.'s Avatar
D.T.
Glad I found this thread!
Can anyone tell me where the "J" assembly plant is?
18J302353
Looks like some bastard pulled out our 350hp motor in our 1969 and put in this 327 for an impala in instead...
Old Feb 9, 2008 | 04:09 PM
stingr69's Avatar
stingr69
Probably a "660" or a "678" block. Large journal 327 block. There isn't anything notable about it. It is just a 2-bolt main 4" bore base engine that is not original to your car. Similar to what was in your car when it was new except the crank has a shorter stroke so you have less displacement and less torque potential.
You can keep it as a 327 or make a 350 or even a 383 with it if you want. A torquey 383 would proably be my choice for the current application. Your '76 would LOVE it.
-Mark.
Old Feb 9, 2008 | 04:32 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
-Mark.
Built a 383 for my vette too. But a solid lifter 327 or even 302 is a lot of fun. Had a solid lifter 302 that started really pulling at 4000. It was still pulling good at 8000 rpm and felt like there was more RPM capability there.
Old Feb 9, 2008 | 06:02 PM
D.T.'s Avatar
D.T.
Originally Posted by FrankVincent
J=Janesville, Wisconsin ...
Thanks Frank!
Complete numbers are:
TO O625HN
18J302353
82396124
Any idea what the #3 is for after the J? How about the last 8 numbers?
To So, what is my engine...
