my thoughts
Old Jul 4, 2007 | 05:17 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default my thoughts
I am tabling a turbo motor for awhile.
So these are my new thoughts.
355ci small block
Weiand Xcelerator (gasket matched)
Superflow heads (190cc RHS/protopline knock offs)(ported)
Scat 9000 crank
5.7" rods
4cc flat top pistons
Probe 1.6 Ratio shaft rockers ($539 bucks, woot woot)
I have 2 thoughts on camshafts
1.) solid flat tappet - cheap and does a good job
2.) Its an OE hyd roller block so hyd roller
Here is my thoughts camshaft
Solid:
http://www.crower.com/misc/cam_spec/...=00321&x=0&y=0
Hyd roller:
compcams XR276HR
276/282 224/230 .503/.510
I think either one will work out really well.
The other thing that concerns me. Headers. I have been told that dynomax blackjacks will work with my angle plugs, though the thought of hooker supercomps excite me as well.
Old Jul 4, 2007 | 09:10 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
If you are trying to save money with the camshaft and cast crank why are you using $550 shaft rockers ?
I am no expert on turbos but the parts you have would be good to 550HP
Old Jul 4, 2007 | 10:25 PM
Guru_4_hire
Cruise-In V Veteran
because I like shaft rockers.....
I might buy a forged crank, I havent decided yet.
Old Jul 4, 2007 | 11:11 PM
BigBlockk's Avatar
BigBlockk
Why do you like shaft rocker arms? In this application what will they do that other, more conventional, systems won't?
BigBlockk
Later.....
Old Jul 5, 2007 | 05:13 PM
Guru_4_hire
Cruise-In V Veteran
Just more rigid, precise, and not much more expensive.
To my thoughts
