Need timing pointer replacement suggestions
Old Oct 29, 2001 | 09:14 PM
BLT-71's Avatar
BLT-71
Default Need timing pointer replacement suggestions
I am in the assembly stage of my rebuild. I put on an aluminum timing cover to replace the bent up original. ]
Now I have a problem with the pointer sets out too far past the front of the balancer. I have seen a few 20+$ pointers but I just need something solid but inexpensive.
By the way I have an 8 inch balancer.
Old Oct 29, 2001 | 09:16 PM
Chris@VetteFinders's Avatar
Chris@VetteFinders
Platinum Supporting Dealership
Default Re: Need timing pointer replacement suggestions (BLT-71)
Do yourself a favor and buy a timing tape (while you are at it)
Old Oct 29, 2001 | 09:29 PM
BLT-71's Avatar
BLT-71
Default Re: Need timing pointer replacement suggestions (Rhys)
My new balancer has timing to 60 degrees even though I use an adjustable timing like to check vacuum, mechanical advance.
Just can't seem to find an affordable pointer.
Old Oct 30, 2001 | 09:33 AM
KenSny's Avatar
KenSny
We used to figure out where TDC was and mark the timing cover, then spot weld a pointer so it lined-up with the dampner mark. With a non-steel cover you can maybe use JBweld or something.
Old Oct 30, 2001 | 12:28 PM
Gordonm's Avatar
Gordonm
Default Re: Need timing pointer replacement suggestions (KenSny)
My Fluidamper is also marked. I took the original pointer and ground it to a point at the 0 degree mark. I use this to point at the degrees at the balancer. Cost me nothing just a little grinding time.
Old Oct 30, 2001 | 01:36 PM
Lt1er's Avatar
Lt1er
Sometimes you just have to explain to the kids why they don't get any food today! Or if thing really cost alot no beer for Dad. I have a $25 pointer from Summit. I have one of those chrome tabs with plus and minus ten degrees that just used two cover bolts to hold it down. Those are probably only a few bucks.
To Need timing pointer replacement suggestions
