HEI Tach Upgrade Question?
Old Dec 8, 2010 | 03:33 AM
RunningMan373's Avatar
RunningMan373
Originally Posted by kerry74
I checked the wires and they both went into a stock wire harness and traveled down the firewall toward the transmission on the starter side of motor. Guessing thats my indicator that they are both stock!
No, stock would have the mesh covered wire going to the starter as you saw, but the main tach power wire would go to the large connector under the brake booster, as stock. Trace the orange wire out to it's end, and see how it's powered/where it goes. if you just want to run your own wire, you can tap in to the main fuse panel under the drivers dash with a female lug and a 12 gauge wire and hook it to the IGN tab. Other end to the Batt tab on the Tach. There should be a plugged hole just above the fuse panel. C.
Old Dec 8, 2010 | 11:31 AM
JohnRR's Avatar
JohnRR
I just had my '73 tach converted to electronic($240) and kept the stock face. I also had my oil pressure gage converted too. Here's the guy to talk to:
Corvette Instrument Service
Roger Scott
9627 Begonia St.
Palm Beach Gardens, FL 33410
561-627-9345 (weekdays 9-5 only please)
Good luck,
John
Old Mar 27, 2014 | 04:16 AM
Vogast's Avatar
Vogast
Do I understand correctly that there are three ways how to run a new HEI distributor with a tach on my 69 Vette.
1) replace manual tach for 75 tach
2) convert original manual tach to electronic
3) install tach filter?
4) other options?
Old Mar 27, 2014 | 05:22 AM
OzzyTom's Avatar
OzzyTom
4) other options?
You're missing the obvious....
buy an HEI mechanical tach drive distributor. (From $60~150 on eBay)
No need to change your tachometer.
Old Mar 27, 2014 | 08:34 AM
augiedoggy's Avatar
augiedoggy
Originally Posted by msandym
I purchased from star performance , an HEI dist with mechanical tach drive that blew up in 3 days . They wanted to see it , sent me a new one (looked different)and it and my tach have been working fine for 3 years .
I also went with an HEI mechanical tack drive for my 74.... time will tell if I made a mistake I guess...
Old Mar 27, 2014 | 10:41 AM
my 76 ray's Avatar
my 76 ray
4) other options?
The tach filter will not make the tach run. It is installed in-line with the electronic tach to clean up the signal.
Old Jul 19, 2014 | 10:19 PM
Tumblershawn's Avatar
Tumblershawn
Great forum. Got a question, a couple quick searches, now looking for a 75-76 tachometer!
Old Jul 19, 2014 | 11:16 PM
'75's Avatar
'75
PM sent
