Aluminum radiator
Old Jul 9, 2007 | 07:24 PM
75 Hot One's Avatar
75 Hot One
Originally Posted by Z-man
I did some more checking. It looks like most C3s, large or small block, had aluminum radiators. If you have A/C, then they were brass. Tom D. can probably provide more accurate details.
As far as I can tell, most C3 radiators were copper as was mine in a 1975 L48. I believe only a few high performance early C3's were aluminum.
Old Jul 9, 2007 | 07:33 PM
Xakk's Avatar
Xakk
Even without the fan shroud, make sure you seal up between the radiator and the support and between the support and the hood. A front spoiler can also helps to channel the air to the radiator.
Old Jul 9, 2007 | 08:14 PM
OzzyTom's Avatar
OzzyTom
Z-man..... where did you find that info ?
I'm not aware of the standard use of aluminium radiators in C3's from the factory ???
tom
Old Jul 9, 2007 | 10:21 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
This would apply to 68-72 small block, base cars only. If these cars had no air, no auto, and no option engine, then it got the aluminum radiator. If the 68-72 sb had any of these options or any combination of them, then it received the 26" copper radiator. That includes L46 or LT1 cars. All C3 73-82 had copper/brass radiators.
Old Jul 9, 2007 | 10:27 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
My 72 Base engine, no ac, auto had a copper/brass radiator. My 63 has an aluminum harrison (stock) go figure!
Old Jul 9, 2007 | 11:36 PM
kaiserbud's Avatar
kaiserbud
that's wierd that they put an aluminum radiator in a no option car? Wonder why?
Old Jul 10, 2007 | 01:29 AM
Z-man's Avatar
Z-man
Whoa! I didn't know that the 73s on up didn't have aluminum. Most of the C3s I see are the early ones, so I assumed that the newer ones had them too!
Old Jul 10, 2007 | 12:25 PM
Overlord's Avatar
Overlord
From: Crush your enemies, see them driven before you, and hear the lamentations of the women TX
I like this aluminum radiator. Never goes over 185. It's an AC car but naked from the firewall forward. I need to look at filling that space in the engine compartment in. I'm in TX too so it's vaguely possible that I'm a heatsink for the engine. 97 today.....
Old Jul 10, 2007 | 12:43 PM
25th silverbullet's Avatar
25th silverbullet
St. Jude Donor '05-'07
Originally Posted by Kalway
Are you tripping? I'm running a stock water pump with my northern factory aluminum radiator and I can't even get the thing over 200 after beating the tar out of it at autocross.
Same here.... I used to worry about the engine being too cool.
