Aluminum radiator
Old Jul 7, 2007 | 08:57 PM
TexasFight's Avatar
TexasFight
Default Aluminum radiator
In the summer I continually have a problem with overheating. If I run the A/C (a must in TX summer) the temp goes north of 220. If I cut it off it does not continue to go up and may drop a little. I roast in the car but at least make it where I am going. I put the dual spal fans on last year but they don't seem to do much in the scorching heat w/ the a/c on. . So the question is- Time to change the radiator and if so to an aluminum?
Old Jul 7, 2007 | 09:24 PM
DeeVeeEight's Avatar
DeeVeeEight
Hi,
I just posted thjis in General a few minutes ago.
Seal it up
Make sure that your fan shroud seals against the radiator support snugly. Purchase some soft tubular black rubber pipe insulation and some weatherstrip adhesive, make seals from it and seal up any gaps between the shroud and support. Also check the top of the radiator support. Is there a seal there to stop air from flowing over the top of the radiator? If not, use some more insulation and make one, or you can get the seals from Doc Rebuild.
Another item to check is the lower radiator hose. They are supposed to have a spring in them to prevent them from collapsing at high RPM's, the water pump can suck them shut, like a drinking straw collapsing.
Another frequently recommended solution is to drill a 1/8" hole in your thermostat to prevent air from getting trapped in the cooling system.
I hope that helps!
Old Jul 7, 2007 | 09:26 PM
DeeVeeEight
That is the low-buck approach.
If all else fails, contact Tom DeWitt (a supporting vendor here) and he will help you keep your cool.
Old Jul 7, 2007 | 09:58 PM
Kalway's Avatar
Kalway
Radiator is probably clogged. I'd try giving it a good flush and refilling it with a 50/50 mix of anti-freeze and distilled water and see if that helps the temps a bit.
Old Jul 7, 2007 | 10:15 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
What about the water pump.. If you have a stock flow pump, you'll need to upgrade.. Even if you put a top of the line aluminum radiator in there, it still won't cool enough with the stock flow water pump.. You need a pump with at least 30% more flow.
I personally use a Pro Comp aluminum pump with 35% more flow than stock and a Griffin Universal Radiator (bolted right in).. Total cost for both was slightly over $200 ($159 for the radiator and about $50 for the pump)
http://forums.corvetteforum.com/show....php?t=1677197
As you are in Texas, you probably won't see too many days with freezing temps, so you could also run straight water with Water Wetter.. That change alone should lower your temperature by 20 degrees or more..
I'm running above mentioned mods as also a auxiliary 16 inch electric fan.. The temperature, even on a 95 degrees summer day in stop and go traffic never goes above 190 degrees with a 185 degrees Thermostat..
Old Jul 7, 2007 | 11:20 PM
DVNTST8's Avatar
DVNTST8
From: if you have a ? on my avatar, please contact me directly, you spineless twit
St. Jude Donor '09
I agree with all of the above, however, check the seals first. If the air is going around your radiator, doesn't matter how good the rad, pump or hoses are.
Did the whole deal, DeWitt'or with the aluminum radiator with the dual Spals, new hoses, and a seal kit from Dr. Rebuild. Can't get her above 190* now.
Old Jul 8, 2007 | 12:32 AM
kaiserbud's Avatar
kaiserbud
I was just about to make a post on aluminum radiators....
I need to consider a new radiator and was thinking aluminum with dual fans... BUT ! Would the aluminum radiator have maintenance issues - inside and out?
Old Jul 8, 2007 | 01:06 AM
Z-man's Avatar
Z-man
They came stock with aluminum - why would there be problems? There are many benefits to using aluminum.
I've got a Griffin 19X31 with a 16in. electric fan and have no problems at all.
Old Jul 8, 2007 | 01:48 AM
Kalway's Avatar
Kalway
Are you tripping? I'm running a stock water pump with my northern factory aluminum radiator and I can't even get the thing over 200 after beating the tar out of it at autocross.
Old Jul 8, 2007 | 01:51 AM
Gearhead74's Avatar
Gearhead74
Default Aluminum Worked for Me
I replaced a perfectly good OEM radiator on a moderately modified 74 small block because the normal running temperature was consistently around 220. (I live just outside Dallas, TX.) BeCool advertised a 20 degree drop with their radiator. That's just what I got. Consistently 200 degrees max with the OEM mechanical fan and no other changes. I had to modify the shroud a bit (their doc warns of this) to clear the lower hose.
Old Jul 8, 2007 | 02:03 AM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
My 72 LT-1 would constantly overheat with the a/c (yes, factory a/c) in traffic here in Texas in the summer. All I did was put in a Dewitts alluminum radiator with new seals and stays cool now. Stock fan and waterpump.
Old Jul 8, 2007 | 12:27 PM
kaiserbud's Avatar
kaiserbud
Sounds like you all are having great results with the aluminum upgrade. In my situation, I have bought an Edelbrock Alum H20 pump - has higher and equal flow.
My next step is the radiator as well so with TexasFight, I have the same concerns. I do not recall radiators that were stock aluminum except for certain few hiperf motors. - which came stock aluminum.
Old Jul 8, 2007 | 05:18 PM
TexasFight's Avatar
TexasFight
Thanks for the feedback. Since I no longer have the original fan/shroud (replaced by the dual spal) would the recommended insulation be the same or similar? I replaced the water pump last year and put on a 160 deg thrmo. I will check the lower hose as well. Thanks
Old Jul 8, 2007 | 05:35 PM
DeeVeeEight
If I understand you correctly, the only area left is the top of the radiator support. Fill the gap between the top of the support and the hood so that air goes through your radiator instead of over the top of it.
Old Jul 8, 2007 | 11:10 PM
GrandSportC3
I probably won't need all the things on my cooling system but there is no such thing as overkill when it comes to cooling.. If you can keep the temperature close to the thermostat rating, you have a efficient cooling system.. That's what matters.. I'm sure that I could drive through Death Valley at 125 degrees and still would only run 190 degrees
Old Jul 8, 2007 | 11:28 PM
72INNM's Avatar
72INNM
Cruising
You won't be disappointed with the Dewitt. I replaced the leaking orginal in my 454 with the Dewitt aluminum and a lower temp thermostat. It's hard to get the car over 180 degrees. Make sure you clean/flush the system before you put in the new rad.
Old Jul 9, 2007 | 05:36 AM
Kalway's Avatar
Kalway
Your engine's oil begs to differ! Unless you're running like 0w30 or something. :P
Luckily no water is pumped through until the thermostat is open...
To Aluminum radiator
Old Jul 9, 2007 | 07:13 AM
GrandSportC3
That's what I meant.. If the cooling system is effective, you'll be running at the temperature determined by your thermostat...
Old Jul 9, 2007 | 11:43 AM
Z-man's Avatar
Z-man
I did some more checking. It looks like most C3s, large or small block, had aluminum radiators. If you have A/C, then they were brass. Tom D. can probably provide more accurate details.
Old Jul 9, 2007 | 12:57 PM
kaiserbud's Avatar
kaiserbud
hmmm - I did not know that regarding the use of alumimun radiators in most production cars - thanks !
