solid lifter or hyd how can you tell
Old Jul 8, 2007 | 05:52 PM
ukester's Avatar
ukester
Default solid lifter or hyd how can you tell
which lifter is in this car i am working on??it is a 68-74 350 i have the intake off and would like some help knowing what lifter i have to adjust them..there is a steel clip on the top of the lifter if that helps
thanks mark
Old Jul 8, 2007 | 05:58 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Once pushrod slack has been taken up between the lifter and rocker, the solid will immediately begin moving the valve, where as the hydraulic will move the plunger into the lifter before valve lift begins.
Old Jul 8, 2007 | 08:09 PM
dmaaero's Avatar
dmaaero
Solid lifters also have a clip, but when you take em apart there"s no spring in there.
Old Jul 8, 2007 | 08:17 PM
Ironcross's Avatar
Ironcross
If it has a cast iron intake or a 5500 red line it more likely has a hydraulic cam with out even opening it up. Besides very few new owners of old Vettes will ever install a solid cam.
To solid lifter or hyd how can you tell
