Fuel Rail Connection/hose issues? (pics)
Old Jul 9, 2007 | 10:34 PM
CorvetteDave01's Avatar
CorvetteDave01
Default Fuel Rail Connection/hose issues? (pics)
I am worried about the lower fuel connector particularly as once I assemble the fuel rail and injectors, if this thing leaks I'm going to be SOL and have to dissassemble the thing in the midst of gas spraying all over.
I put a pipe fitting/-6 AN "L" into the fuel rail, then a short piece of braided -6 AN hose with a -6 AN hose fitting on either end. Anyone see any problems with this?
Old Jul 9, 2007 | 11:32 PM
Z-man's Avatar
Z-man
If I understand you correctly, I don't see why it wouldn't work. Keep the radius gentle so there is as little resistance to flow as possible.
Old Jul 10, 2007 | 10:35 AM
shafrs3's Avatar
shafrs3
If everything is assembled correctly it should be bullet proof. Your ECU should have a short timed fuel system priming event when ignition is first switched on you can use to check for leaks, mine is around 5 seconds.
It's good to be paranoid about fuel leaks.
Old Jul 10, 2007 | 09:15 PM
Chandler's Avatar
Chandler
That seems like the best plan. Maybe one of the ends needs to swivel so you can tighten it without twisting up the hose.
Old Jul 10, 2007 | 09:22 PM
Scott Marzahl's Avatar
Scott Marzahl
Where is your fuel supply line coming from, if from below as original, I would use at least a 45 degree fitting instead of a straight one on the supply hose.
Old Jul 10, 2007 | 11:03 PM
CorvetteDave01
OK thanks guys. I forgot about the fuel priming and I will try the 45 degree fitting instead of the straight one.
Old Jul 11, 2007 | 02:36 AM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Here's a though and since I cant see everything around your motor take ti with a grain of salt.
What I would do; plug fwd ends of fule rails and plumb the fittings into the rear of the rails. ring the flex lines up from the frame rail to the back of the motor. You'ld probably have a bit more room to work around the Dist. instead of having to deal with belts, T-stat and other stuff on the front of the motor.
After doing 1 FI car I learned alot of little things
To Fuel Rail Connection/hose issues? (pics)
