Fuel Pump on 454
Old Jul 11, 2007 | 03:13 PM
72-454's Avatar
72-454
Default Fuel Pump on 454
I need a fuel pump with more flow on my 454 Corvette. Don´t know what pump is installed now. So, does anybody know what high flow pumps fit between the engine block and the frame? Also need some advice on fuel return line. Can I possibly block it off if a new pump doesn´t have a plumbing for it?
Old Jul 11, 2007 | 03:41 PM
Dr.G's Avatar
Dr.G
I have a Holly mech pump on my 72 454. Direct bolt on no problems.
If interested I can find the #'s for you
Dave
Old Jul 11, 2007 | 03:51 PM
72-454's Avatar
72-454
Yes would like to know the numbers, also the flow rate if you have. Thanks in advance.
Old Jul 11, 2007 | 04:22 PM
GDaina's Avatar
GDaina
I find it hard to believe the stock GM BB pump can't handle the fuel needs, after all, the same pump was used on all of the Hi Po engines, L-88, ZL-1, and tri power.
Old Jul 11, 2007 | 04:25 PM
Dr.G's Avatar
Dr.G
summit part # HLY-12-454-11
110 gph 6-8psi
Old Jul 11, 2007 | 04:29 PM
Dr.G's Avatar
Dr.G
You are probably right, but since I had to replace the one on my new motor, I did not want to go with the same brand I had to replace.
Dave
To Fuel Pump on 454
