I recieved an e-mail from a friend that needs a little help. I am hoping someone here can help. Here is what he sent.
can you get on your corvette forum and find out if anyone has replaced there rear trailing arms on a 72 vette and how they dealt with the rusted TIGHT bolts in the front of the trailing arms., You cannot get a straight shot on hitting them out., you can just get a wrench on the head to try and turn it., but thay are rusted to tight to even think about moving., Torching will not work without severely damaging the frame and body.
Try some liquid wrench or similar type loosener. If it's really stubborn, get some on there, let it sit overnight and hit it again. Good luck. They can be a bear...
Pull the shims out with a pointed pry bar. After they are out of the way you can saw off or burn the bolt off your choice. I cut the head off the bolt with a metabo and burn off the bolt between the trailing arm and the inter frame (nut side)and the arm falls out.
Sawzall and 8" blades. The procedure is covered multiple times in the archives.
8 rescue blades that is
I did my 72 which is just like and other C3 and had to cut them off by using lots of oil and lower RPMs on the saws all with what is know as rescue blades. one side cut thru in 2 minutes and the other side was about 2 hours. You have to get a good angle and try to be on the bolt and not the rusted in shims if possible.
Good Luck,
Jim
I just used bi-metal DeWalt blades. It only took three of them.
the rescue blade works very well. to keep from hitting the back of the pocket, light the area well and start cutting with the blade extended all the way out, cut with just the tip, and hold the saw still.
If you guys made an 8" blade, you'd have the perfect solution.
How did you avoid slamming the blade into the back of the pocket? It's a rather unpleasant sensation when it hits...
It's trial and error. You have to hold the saw far enough away that it won't hit. I used 1 blade per cut (total 4) to get the trailing arms off the 72. I couldn't budge the inner shims on either side. I had a really hard time getting the trailing arm bolts cut on a bare frame. I'm sure I'd be homicidal if I were trying to do it with the body on the car.
i only used 1 blade per side and it was body on. the trick is to sit on a brake job stool inside the wheel well. you have to put the car up really high. a lift makes it even easier.
We do make 8 inch blades in the metal cutting tooth configuration. I had some 9 inch blades and just ground the tip of it off. The 6 inch is most common but we do have some 8,9 and 12 inch ones also. http://www.lenoxsaw.com/recip_gold.htm
I couldn't find a local distributor of Lenox blades when I was fighting my T/As - so I grabbed what was available. I did look, though.
Plumbing and electrical supply houses will carry the full line if they are a Lenox dist. Lowes and HD only carry a select few SKUs of blades. Also some Industrial supply houses will have them. Thanks for looking for them.
Did my 78 with a saws-all and 8 blades from home depot.
Had to cut through the shims on each side of the bolt.
The trailing arm rubber bushing bound everthing together, along the bolts. The entire operation for both arms took about 4 hours.
Well worth the effort. I used anitsieze on the new shims and trailing arm bushings, and bolts, before putting together.
