Reasonable HP Gains
Old Jul 16, 2007 | 02:40 PM
KevinK's Avatar
KevinK
Originally Posted by yel76low
How much can you expect to pay for used Vortec heads?
And how much of an improvement will you see?
I have no idea to the first quesion, though I would say at least 1/2 the cost fo new vortec heads......
As for improvement, you will see a pretty big gain. However, before waisting money on heads, you need to decide what exactly you want to do with it first. Make sure about the decision, otherwise, you might just find yourself buying yet another set of headers, and that sucks.
Old Jul 16, 2007 | 09:31 PM
FLPLAYTIME88's Avatar
FLPLAYTIME88
i have been working on mine for about 2 months now...what a blast !!!...money is going quick
i did headers first...with side pipes ...on a scale from 1-10..about a 3 on more feel in the pedal
complete tune up...2 more
changed out 3.08 rear gear for a 3.70...7..yep !!
swapped out th350... 700r4...so i could get back on the highway
.....next cam... vortec heads and intake manifold...
the hard part is trying to figure which cam to use..
i have talked to summit and comp cams each twice...i get different recomandations every time
good luck to you
and remember.... it all about having fun !!!
steve
used vortec heads... about 300.00- 350.00
Old Jul 16, 2007 | 09:41 PM
Glensgages's Avatar
Glensgages
good luck to you
steve
Maybe this'll help:
http://forums.corvetteforum.com/show....php?t=1745688
it could-be burnin'-gas n' rubber anytime now!!!!!
Old Jul 16, 2007 | 09:51 PM
Meatburner's Avatar
Meatburner
Originally Posted by supervette77
Get your distributor, carburetor and timing set up according to Lars papers and throw on a set of headers and true duals with no cats. This will give a very noticeable seat of pants difference in performance right off the bat at a very modest cost. If your budget allows, the changes that the others have mentioned will certainly make a significant difference in performance no doubt. Changing the exhaust system over alone will wake up some sleeping ponies.
Larry, that is the first thing I want to do. Past experience has proven start with the basics and work from there. I really need some help with the headers and exhaust vendors. A complete exhaust system is what I am looking for and see what header vendors are recommended. I don't have an interest is the cheapest parts, you get what you pay for...within reason. Any suggestions from the forum will be greatly appreciated.
Old Jul 16, 2007 | 09:57 PM
yel76low's Avatar
yel76low
Yeah, I was just wondering for future reference.
Old Jul 17, 2007 | 07:28 AM
Durango_Boy's Avatar
Durango_Boy
Personally I have always liked the fit and quality of Hooker headers. I would suggest a set of those with some good copper gaskets and then drop the car off at a reputable exhaust shop. Let them finish the system off with a true dual, 2.5" system, with a pair of Magna Flow mufflers.
I have gone back and forth between Magnas and Flows and always have found Magnas to be more appealing to my tastes.
