68 vac. power booster
Old Jul 13, 2007 | 02:28 PM
omc's Avatar
omc
Default 68 vac. power booster
Does anyone know if the 68 vac. powerbooster that bolts to the firewall with mastercylinder was it a 2-bolt on or was it 4-bolt on system? also if its a 2-bolt which i am hoping it to be can it still be purchased????
appreciate the help
Old Jul 13, 2007 | 02:40 PM
SIXFOOTER's Avatar
SIXFOOTER
I just looked on Ecklers, looks like all the pics they have are a 4 bolt on the firewall side and 2 olt on the MC side, but those could be generic pics
Old Jul 13, 2007 | 02:57 PM
omc's Avatar
omc
yes, i also have looked and i am hoping that it is just a generic picture for general sales. hope someone that has a 68 might know.
Old Jul 13, 2007 | 04:24 PM
682XLR8's Avatar
682XLR8
Yep, it's a four bolt.
Old Jul 13, 2007 | 04:42 PM
RPOL68's Avatar
RPOL68
Default Retrofitting?
If you are looking to retrofit your non-power system, the 4 bolt booster (Delco or Bendix) will fit. You will need to drill the additional 2 holes and do a little clearance filing, just as they did at the factory except your job will be a PITA because the dash is in the way.
The two studs that the M/C bolts to are held in place with tabs on the pedal support assembly. You will have to bend the tabs, remove those bolts then slide the booster into place and secure the booster studs with nuts and lock washers. Easy when everything is off, incredibly difficult with the dash in place, but doable.
To 68 vac. power booster
