Intake manifold ?
Old Jul 14, 2007 | 02:39 PM
HO-alts-Rick's Avatar
HO-alts-Rick
Default Intake manifold ?
Ok the one I bought doesn't fit, it's to tall. What intakes are people using? It's on an 81.
Old Jul 14, 2007 | 02:50 PM
HO-alts-Rick
Anybody using a edlebrock 2701?
Old Jul 14, 2007 | 04:07 PM
my mach 5's Avatar
my mach 5
Is that the intake you bought? That's the EPS manifold and that should fit.
Old Jul 14, 2007 | 05:33 PM
1fastC3's Avatar
1fastC3
ive got a performer eps with a 1in HVH spacer, drop base air cleaner and a demon 750 with maybe a 1/2-3/4in. clearence between the top of the stud and underneath side of the hood. I used some clay measured a dozen times and it all worked out, I have a 77 with cowl hood, I dont know how much of a rise your hood has or if this setup will work out for you, even if it does not someone else may benefit from this post, hope this helps and good luck with what ever you decide.
-alex
Old Jul 14, 2007 | 06:36 PM
guitarcrazy02's Avatar
guitarcrazy02
What manifold?
Old Jul 14, 2007 | 09:26 PM
SIXFOOTER's Avatar
SIXFOOTER
What was wrong with the EDL2101 it came with? Thats a good unit on a mild mod motor
Old Jul 15, 2007 | 10:25 AM
Ed Blue 03's Avatar
Ed Blue 03
The Torker II is a low profile manifold.
To Intake manifold ?
