74 A/C QUESTION what to do.
Old Jul 14, 2007 | 08:40 PM
DARROW's Avatar
DARROW
Default 74 A/C QUESTION what to do.
Compressor has a small leak also a hose is leaking.
time for a upgrade.
Do they make a kit for this or should I buy parts seperatly. Or should I just have the compressor rebuilt?
Old Jul 14, 2007 | 09:08 PM
SIXFOOTER's Avatar
SIXFOOTER
AC hoses are available at Ecklers, corvette america, all the big suppliers. Compressors are availablt at most parts places. You will need a new drier also. If your concidering going to R134A the system will need to be flushed to get all the old oil out and a new paralell flow condensor will be a good idea.
Old Jul 15, 2007 | 07:54 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Just as a side note, I would stay away from Ecklers, particularly when dealing with a/c parts. I ordered a hose from them last year which turned out to be wrong and then they tried to pass of an evaporator as a new Delco part when after research it turned out to be a reman. unit. I finally got the hose from Corvette Central. Frankly, I think Ecklers has gone to pot over the past few years. Expensive and low quality in general.
Old Jul 15, 2007 | 08:47 PM
DARROW's Avatar
DARROW
I agree thanks
Old Jul 15, 2007 | 10:23 PM
ajrothm's Avatar
ajrothm
I would stay away from rebuilt compressors. Those front seals are pesky leakers on A6s and you will no doubt be pulling it back off in no time.
You can get a new A6 from www.ackits.com for $360.
If you do decide to buy a rebuilt, I would at least get a AC delco reman.
To 74 A/C QUESTION what to do.
