Rear Window Moulding
Old Jul 15, 2007 | 02:03 PM
check714's Avatar
check714
Default Rear Window Moulding
Is there a trick or special tool needed to remove the rear window moulding on an 81. I am making an attempt to dress up what I have, but would also like to have the option to replace the moulding in the future. I have tried corvette centeral and mid america with no luck. Would appreciate additional insight on a vendor as well.
Old Jul 29, 2007 | 08:55 AM
Electricblue80's Avatar
Electricblue80
Default This should help.
I found the cheapest one on on this site, but you can search for it on google, etc. Its called KD2038.
http://www.etoolcart.com/index.asp?P...OD&ProdID=1138
Old Jul 29, 2007 | 09:30 AM
check714's Avatar
check714
Old Jul 29, 2007 | 09:40 AM
check714's Avatar
check714
Any luck locating the molding. I found one on this site but the seller pulled back because it was damaged
Old Jul 29, 2007 | 10:31 AM
celeryman22's Avatar
celeryman22
Good luck finding the molding. To my knowledge no one makes it new. I ended up finding a used one at one of the covette junkyards.
Mike
To Rear Window Moulding
