brakes for a 1980
Old Jul 15, 2007 | 09:21 PM
tinman2's Avatar
tinman2
7th Gear
Default brakes for a 1980
going to do a complete brake job on my 80 L82 . I need some direction on where to get the parts , what to look out for , pros and cons . any advise would be great , thanks tinman2
Old Jul 15, 2007 | 09:27 PM
Durango_Boy's Avatar
Durango_Boy
Lots of great vendors to choose from. I bought all my calipers from Autozone though. Local, easy core exchange, lifetime warranty, S/S sleeved, and cheap. If I remember right, they were $69.99 EA.
I suggest new rear hard lines for the trailing arms, and new S/S braided flex lines for the calipers.
Rebuild the master with a kit from Oreilly. $25 and an hour and that's it. Drain all the old fluid and replace with new fresh fluid. Make sure you properly bench bleed the master. Let gravity do most of the work for 24-48 hours and then bleed at each wheel several times just to make sure.
Or...buy a Motive bleeder and do it the quick way.
Old Jul 15, 2007 | 09:50 PM
SIXFOOTER's Avatar
SIXFOOTER
This is a decent kit for the $
Its the minumum quality wise that I would do
http://www.vbandp.com/detail.aspx?ID=280
Old Jul 16, 2007 | 06:27 PM
tinman2's Avatar
tinman2
7th Gear
what would be a middle of the road kit?
To brakes for a 1980
