1978 Possible Alarm Problem
Well, now the car won't start and every time we try to lock the car the alarm sounds.
Does anyone have a schematic for this alarm system, or know how to disable it so I can start my car?
Thanks! Mouse
I have pulled the battery cable, hoping to reset, but that did not work either.
Every time I try to lock the door with the key, it activates the alarm. Right now, I have it unlocked. I feel fairly safe as if I can't start it the average idiot won't be able to start it either. LOL.
I am not your average woman, I can troubleshoot most problems, but electrical has never been my strong point.
My drivers window is slower going down then normal if that helps.
If I had a schematic, or at least knew where the fuse was I could probably bypass this alarm.
The book I have (Haynes) pretty much tells me what the alarm does, but not how it is set up.
Thanks!
Thanks!
tiasd
and as far as I know you can't find a replacment except at maybe Dr. Rebuilds.
and as far as I know you can't find a replacment except at maybe Dr. Rebuilds.There is also a pin switch (door ajar) in both door jams. They both have to function correctly or the alarm circuit is compromised. The drivers side door ajar switch connects directly to the alarm circuit.
There is a relay under the center console beneath the ash tray area. An issue with any and/or all of these can contribute to an alarm problem.
Fuse block problem?
Need a circuit diagram and testing equipment to diagnose the system.
Try Corvette Central for diagrams...they should have a schematic of the door and the parts.
I am not aware of ANY theft system stock on a C3 that prevented the engine from starting. My .02. Good Luck
Fuse block problem?
Good luck.
http://corvetteforum.net/c3/tunedpor...l/index6.shtml
Thanks! Mouse
You should be able to lock using interior lock, then close door.
tiasd
What year- you only list 89. I designed a kill switch for C4 up that will not allow someone to hotwire it & does did not disable factory alarm.
The guys at Best Buy wanted to charge me for an extra relay to disable the factory alarm for the 89 Corvette alarm system.
