Timken Rollerized vs Sleeve Bearings
Old Jul 16, 2007 | 08:32 AM
S489's Avatar
S489
Default Timken Rollerized vs Sleeve Bearings
FYI - Interesting:
http://engineeringtv.com/blogs/etv/a...d-engines.aspx
Just for information and discussion, i thought this fell more into tech than general.
i always wondered why the aftermarket/racing didn't attempt roller bearings, with cost nearly no object in that market. Now, it looks like it may be on the horizon for all vehicles; no doubt these days the extra cost could be offset by fuel savings.
Old Jul 16, 2007 | 12:58 PM
gkull's Avatar
gkull
Nearly all high end race motors are rollerized to some extent. Shaft rockers or roller rockers. roller lifters. roller bearing cam shafts are becoming more common. What you don't see very often except in the exotic car motors is roller cranks. You have to have pressed crank shaft journals. Which is easier with less cylinders, like one , two, four like in motorcycles.
Old Jul 16, 2007 | 01:17 PM
S489's Avatar
S489
makes sense; however the man in the video says they are using a split roller bearing on the crank and rods. for a split second you can see one in his hand. will be interesting to follow . . .
Old Jul 16, 2007 | 07:51 PM
mrvette's Avatar
mrvette
No big deal, Neighbor across the street fixed his own Mercury outboard engine 225 hp V6 2 cycle, and it needed a piston...so he got one, hones the cylinder, I see the roller bearings in the con rod standard configuration split race...he dumps grease on them to hold them together, buttons it all up, runs it for a day perfect....cost him about 500 bus in parts.....for a 7 GRAND savings over a machine shop fix....
that engine is full of roller bearings in everything...
Old Jul 16, 2007 | 07:59 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I have often thought of this kind of stuff and wondered when it was going to come about. I figured it had to be in the works. Next, I wonder how long the bearings will last compared to standard babbit bearings.
Old Jul 17, 2007 | 03:41 AM
Frank_833's Avatar
Frank_833
Motor cycles, racing karts and other small to medium engines have used them for a looong time - though these are not 'split'. Instead the cranks are pressed together so you can split the crank to service the bearings.
While I've had 1 catastrophic failure (those little pins running throught the engine ruin everything), I've not seen any other racers have similar failures.
All things being equal, I seriously doubt roller bearings will outlast sleeve bearings in a typical street engine.
I know of no roller bearing engines that typically make it to 20K miles (or equivalent number of hours). Roller bearings also require more surface area to handle the same loads.
Old Jul 18, 2007 | 11:37 AM
slowride262's Avatar
slowride262
Roller bearings rob horsepower in a four stroke engine.
To Timken Rollerized vs Sleeve Bearings
