1977 cruise control help
Old Jul 16, 2007 | 03:27 PM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
Default 1977 cruise control help
I have a 1977 with cc. Its not working seems everything is pluged in????
Any ideas... Thanks for the help CF.
Old Jul 16, 2007 | 03:35 PM
SIXFOOTER's Avatar
SIXFOOTER
Checkout the cruise modulator, its mounted on the fender skirt in front of the firewall and under the brake master cylinder. There is a connector on it and a rather cheesy ground. corvettefaq has a troubleshooting procedure for the system. Does your speedometer work correctly? The cable passes thru the modulator and the mod can gum up and it won't work.
Old Jul 16, 2007 | 07:12 PM
ptroxx's Avatar
ptroxx
Speedo is working fine..
Old Jul 16, 2007 | 09:30 PM
SIXFOOTER's Avatar
SIXFOOTER
Look in here
http://iotech.no/corvette/technical/...se_control.htm
To 1977 cruise control help
