Some ???? Before Start Up
Old Jul 16, 2007 | 09:09 PM
bruced267's Avatar
bruced267
Default Some ???? Before Start Up
Im about ready to start it back up and I have a few questions.
1 Where does the temp probe go when using DCC controls? I have no idea how the cooling system flows.
2 I installed a small cap distributer and the coil has a pig tail for tach and 12v ingnition, is there a 12v ing. source from the old distributer I can use? or do I have to go back to the fuse panel?
Thanks in advance
Old Jul 16, 2007 | 09:56 PM
SIXFOOTER's Avatar
SIXFOOTER
Put the temp sensor down on the bottom pass side of the radiator, the water exits down there so thats the most reasonable place to put the sensor. That will make the fans run when they are needed instead of as soon as the thermostat opens.
There is a switched power wire in the harness from the old dist, use that
