weird stalling
Old Jul 17, 2007 | 02:53 AM
jiber's Avatar
jiber
Default weird stalling
my car is starting to stall out when it is left to idle for about 2 minutes. The voltage gauge is reading about +20 and when ever i press on the gas just slightly the engine cuts out. Im not sure if its an electrical problem or a fuel problem. Any ideas or suggestions would be appreciated.
Old Jul 17, 2007 | 07:51 AM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
i'd lean towards loading up.
Old Jul 17, 2007 | 08:12 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Sounds like a fuel problem to me also. Are you getting black smoke out of the exhaust?
Old Jul 17, 2007 | 08:22 AM
bashcraft's Avatar
bashcraft
I'd say both. 20+ volts will at the least cook your battery. As far as stalling, check to make sure your accelerator pump is working correctly.
Old Jul 17, 2007 | 08:42 AM
Jud Chapin's Avatar
Jud Chapin
I suspect he means 20 amps. If the alt were putting out 20 volts, he'd have a lot more problems.
Old Jul 17, 2007 | 11:59 AM
jiber's Avatar
jiber
ya sorry i meant twenty amps. and there is no smoke coming out of the exhaust and i just had the carb retuned after swapping from automatic to manual.
how do i check the accel pump?
Old Jul 17, 2007 | 02:48 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader Vette
Acc pump I think you hit on somthing there thats what I was thinking it sounded like . Im sure someone will be able to splan getting to that better than me not a carb guy.
Old Jul 17, 2007 | 03:08 PM
weimer20's Avatar
weimer20
Having no idea what carb you are running, the accel pump is usually cam and lever driven. You should be able to look down the barrel of the carb, pull the accel lever, and watch for a fine shot of fuel injecting straight into the barrel. I'd bet it is a fuel issue either way.
Old Jul 17, 2007 | 04:42 PM
jiber's Avatar
jiber
i don't think its the accel pump because the car will stall out if just left alone for a minute or two.
Old Jul 17, 2007 | 05:25 PM
noonie's Avatar
noonie
What carb and how does it run otherwise?
Old Jul 17, 2007 | 06:10 PM
jiber's Avatar
jiber
holley street avenger 670 cfm.
Old Jul 17, 2007 | 08:20 PM
weimer20's Avatar
weimer20
Check the float level then.
Old Jul 17, 2007 | 08:41 PM
weimer20's Avatar
weimer20
Default Check out the post from Lars on the street avenger.
Lars just put in a great post regarding issues with the street avenger carb. Take a read of his post b4 going any further.
Old Jul 17, 2007 | 11:20 PM
jiber's Avatar
jiber
any way i can get a link to that thread?
Old Jul 17, 2007 | 11:32 PM
Avette4me's Avatar
Avette4me
V8fastcars@msn.com - lars e-mail
not sure why weimer20 thinks it could be the acc pump if it's stalling at an idle, sounds like a guess to me. anyway, he is right about lars knowing his shet.
Old Jul 18, 2007 | 07:05 AM
bashcraft's Avatar
bashcraft
Probably because the original poster wrote this:
Old Jul 18, 2007 | 10:12 AM
weimer20's Avatar
weimer20
http://forums.corvetteforum.com/show....php?t=1759376
Old Jul 18, 2007 | 10:15 AM
weimer20's Avatar
weimer20
Sure its a guess, just like a doctor would guess based on symptoms without being able to diagnose. And yes, it was based on a previous post stating that it would stall when the accel was pushed. Anyway, I posted the link to the thread that Lars posted on this. He seems like the best authority on this issue. Best regards and good luck.
To weird stalling
