New Guy (Trying this on "Tech/Perf")
Tried this thread on "General" forum and was told to get manuals. As I responded over there, I live in Florida where it rains whenever, and wanted to get my wipers working pronto.
Thanks for any assistance!!
________________________________________ ______
Hey everyone,
Just registered after spending A LOT of time on the site gleaning bits (and stacks) of wisdom from some Vette Masters.
I just got my '82 Vette this weekend, and here are a few issues I need help with (Please?!): (By the way, I know some of the questions are going to sound silly, but I've been looking for a good manual here in town for two days. No Chilton, Haynes didn't have the diagrams I needed.)
1. My wipers don't work at all. I was glad to hear there was part of the wiper system behind the seats, 'cause I thought I was losing my marbles when I heard a clicking when trying to turn them on.
Does anyone have a wiring diagram of wipers? Where the heck is the fuse? Which leads me to-
2. Does anyone have a picture of the '82 fuse box. I need to know what leads to what. I have already replaced most of the fuses, but wipers still don't work.
3. No power steering. Where do I begin to look after fluid and belt?
4. A saw a thread yesterday about a member regretting he had a cross-fire engine. My Vette is no screamer either. What would you wizened ones suggest? Upgrade chip, new exhaust (love those side-pipes), or, if it's even possible, a new intake manifold with a good old Holley on top.
I believe that's it (for now )
Thanks for any help!!
__________________
No Bubba here (I hope)
Wipers - It may not be a fuse. A few other problems could be the motor and the switch. The first thing I would suggest is testing the motor to see if it functions. Do you have a multimeter? You'll want to test each terminal with the key on and off. The yellow is your IGN circuit so that one should be hot with the key. Make sure it's getting power when the key is on, when the switch is on, and that it has a good ground.
Crossfire engines have a lot of potential but like all engines it needs constant care and attention. You'll be pleasantly surprised with what you get out of a complete tuneup including timing the motor.
82 was after the switch to Corvette-only manuals, so it's possible that some of those above books were consolidated into the Corvette service manual. Helm still publishes the manuals, but I find that eBay is the best source - with a bit of looking around, you can get good condition manuals for low prices.
Grateful for any input.
Thanks for the tip. Not much at soldering though.
By the way, that delay wiper controller was laying on the bottom of the well there (apparently fallen out??) When I was looking at it, noticed the board seemed loose. Bet your right!
Thanks a bunch.
Amazing thing yesterday. I was putzing around with the conncection to the wiper motor and the delay relays. When I fired it up, my wipers moved up about 2 inches. But that's all. Couldn't get them to duplicate, so I don't know if it was the motor or relay. Now if God will just let it rain on that 2 inch bit of coverage, I may be OK.
About those wiper motors, that sounds great (Ain't to proud to beg, as Mick would say). And if you don't return, should I call a search and rescue team or just skip right to the coroner? HA.
Thanks loads, man.
Dave
You have the ground wire attached and the ground wire is grounded-correct?
Heads, cam, exhaust...those are what really needs to be replaced.
The price is a bit high for this used manual though. I think I paid $19 for mine new. The other manuals are not good enough in my opinion.
Crossfire motors are a special breed all its own, but once you get it dialed in they will run great for a long time and are rather reliable. There are a few major areas that need to be addressed with a CF.
1) Fuel pressure is very critical on a CF motor. You must know what the FP is set to in order for the motor to run properly. The FP needs to be 14psi and the motor will run fine...No buts, its a fact with CFI. The GM manual says 9-13psi...NOPE! That doesn't work, trust me on this one.
2) Vacuum leaks are the big enemy of a CF motor. The top plate bolts will loosen and cause issues along with the TB bolts. No buts, its a fact with CFI. Another big area with CF is the TBs themselves. The TB shafts become worn generally at 50K miles and when worn causes a vacuum leak with erratic idle and poor performance. No buts, its a fact with CFI. This condition also makes it IMPOSSIBLE to balance the TBs which leads me to number three.
3) Balance the TBs is also another critical item. No buts, its a fact with CFI. The process isn't very hard, you just need patience and a little practice to get it right, thats another reason for getting the GM manual vs the others. You'll need a water manometer to balance the TBs as well or make one.
4) The CTS sensor in the front of the stock manifold is a major player on a CF motor as well. The sensor takes its ground through the block via the threads of the sensor. Over time, corrosion starts between the threads and and the block and changes resisitance values which causes issues with the readings the ECM gets and will cause the motor to run most of the time very rough and very rich when it shouldn't. The answer is to replace the CTS sensor with the newer two wire weather pack type and don't use Teflon tape on the threads.
5) Timing on a stock motor is 6* with the ETS wire removed. If you have a fair amount of miles on the car...over 75k or so, set it to 8* if the motor doesn't ping using Premium gas of course.
6) Last but not least...GROUNDS!! Grounds are key to a corvette no matter what year you have. They will cause a ton of issues if you have poor grounds. As they say..."You can never have enough grounds on a corvette". The best ground is from frame to block. I added three new grounds when I installed my new motor.
These are but a few of the things to do with a CFI motor and there are more tricks as well, like replacing the stock fuel pump with a 85-87 corvette pump which I didn't mention above.
If you would like more info on a CF, send me a PM and or visit the http://www.crossfire.homeip.net/ website. Hope I didn't scare you away from the CF. Most past owners of a CF that hated the car, just didn't know how to work on them correctly or didn't want to take the time to fix it, but thats just IMHO.
I have had my 82 CF for 13+ years and its a great car and even better with the 383 under the hood now and I'm still using the CFI on the top end and it keeps up with the newer C5 and C6s...LOL
