Hooker side pipe headers and angle plugs
Old Oct 31, 2001 | 07:45 PM
paso's Avatar
paso
Default Hooker side pipe headers and angle plugs
Anyone have hooker side pipe headers and have angle plugs I noticed on the web site they have a disclaimer saying not for use with angle plugs
I have regular Hooker headers on the 77. I don't remember if I got angle plugs or not, but the 76 L48 350 I'm working on definatly has angle plugs. WTF Does that mean they physically won't fit or that the plug is very close to the header pipe and you need to use very high heat resistant plug wires. I hope someone can enlighten me with their past installation. I finally get all the proper #'s and then I read the fine print oh well better now than latter. (that's a first) :)
Old Oct 31, 2001 | 07:51 PM
1979toy's Avatar
1979toy
Default Re: Hooker side pipe headers and angle plugs (paso)
I had to use short style plugs on my straight plug heads to have ANY clearance. :mad
Old Oct 31, 2001 | 08:28 PM
JCL's Avatar
JCL
Paso. Same here. Wanted to use the angle plugs, but no go. Wanted the sidepipes more. Went with Iron Eagle's instead. Glad i did bescause it's a great combo for this "litte ole" 383 !!!!! JCL SOUNDS :cool: :cool: :cool:
Old Oct 31, 2001 | 08:39 PM
nastee383's Avatar
nastee383
I have Hooker sidepipes with Sportsman II angle plug heads and only the no.2 plug is even close. The other 7 have plenty of room. I use ACCEL shorty plugs but that's because I HAD to use them when I had Hedman headers and now I've become very fond of them. Be advised all angle plug heads don't have the same angle. Some could cause clearance while others won't.
Old Oct 31, 2001 | 09:20 PM
Mike69@ECS's Avatar
0Mike69@ECS
Former Vendor
Cruise-In III Veteran
Cruise-In V Veteran
I'm running The Hooker header / Sidepipe combo with the angled plugs on my ZZ4. One plug is pretty close but they clear just fine!
Old Oct 31, 2001 | 10:08 PM
Nomad78SA's Avatar
Nomad78SA
Default Re: Hooker side pipe headers and angle plugs (Mike69)
I have Trick Flow 23 degree angled plug heads on my 78 Corvette. I have no problems. The plug holes have been relocated on the TF heads for this reason. One plug I had to tighten with a wrench for a socket whould not fit around the header #1 plug I beleive.
Neil in Tenn
[Modified by Nomad78SA, 8:09 PM 10/31/2001]
Old Oct 31, 2001 | 10:48 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Hooker competition plus header side pipes + Twisted wedge angle plug heads.
# 2 plug is tight but managable :smash:
Old Nov 1, 2001 | 03:58 AM
1979toy's Avatar
1979toy
Default Re: Hooker side pipe headers and angle plugs (yellow 72)
Looks like a better fit than my straight plug heads!
Old Nov 1, 2001 | 07:18 AM
SmokedTires's Avatar
SmokedTires
St. Jude Donor '05
Paso, I have the Hooker sidepipe headers on my sbc with angle plug Sportman II's like Nastee383 with no problems. :)
Old Nov 1, 2001 | 08:47 AM
paso's Avatar
paso
Default Re: Hooker side pipe headers and angle plugs (1979toy)
I wonder now why they would put that disclaimer? The one I'm working on has stock heads. Are the stock heads at a differant angle than the others? If it's only one or two plugs that are tough to get in and out ah gee. I could live with that put the pictures submitted don't lok like a problem at all.
To Hooker side pipe headers and angle plugs
