New Puel Pump
Old Jul 18, 2007 | 08:52 PM
Doug Maitlen's Avatar
Doug Maitlen
Default New Puel Pump
I am going to install a new Bosch fuel pump on my 79 tomorrow. Is it a simple unbolt, clean, lube, and reinstall job? I read the other fuel pump install thread and I am wondering if I will have to go through all that trouble.
Old Jul 18, 2007 | 11:34 PM
jdp6000's Avatar
jdp6000
Should be. Just put enough grease on the rod so it stays up until you get the pump on.
Jim
Old Jul 18, 2007 | 11:44 PM
BKbroiler's Avatar
BKbroiler
If you're using the stock metal line from the pump to the carb, the outlet of the pump might be in the wrong location to accomodate it. I went back to the stock AC Delco pump which allows me to use the stock metal line, bent slightly to fit the taller intake manifold.
To New Puel Pump
