RTV Removal
Old Jul 19, 2007 | 06:20 PM
bytor's Avatar
bytor
Default RTV Removal
Whats the best way to remove the old RTV sealant on valve covers without causing any damage?
Old Jul 19, 2007 | 06:41 PM
gerry72's Avatar
gerry72
Acetone is a pretty good solvent for RTV. Though you should be able to peel most of it off pretty easy.
Old Jul 19, 2007 | 08:26 PM
dmaaero's Avatar
dmaaero
A putty knife and a scotch brite pad work good, especially when the scotch brite pad"s on the end of a die grinder !
Old Jul 19, 2007 | 08:28 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Lacquer thinner will soften it pretty quick.
Old Jul 20, 2007 | 04:03 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I used a spray can of gasket remover and a putty knife, it did the job quite easily.
To RTV Removal
