Lowering engine ??
Old Jul 20, 2007 | 09:46 PM
Michel B's Avatar
Michel B
From: Ville de la Baie Quebec. A winner is just a loser who tried again.
Default Lowering engine ??
Has anyone ever lowered the engine by modifieing the supports to accomodate intake hight ?? Can it be done ??, I'm talking about 7/8inch. It is an interresting thought..
Old Jul 20, 2007 | 10:12 PM
BigBlockk's Avatar
BigBlockk
Cheaper to get a taller hood.
BigBlockk
Later.....
Old Jul 20, 2007 | 10:55 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
I thought for a while about doing this on my spare frame. I'm cutting it up a bunch putting a C4 suspension on it, and I thought about improving the c/g height by lowering the engine. But, given the already low clearance height of the oil pan and bellhousing, I lost my nerve at the thought of doing some agricultural racing and seriously damaging the pan or bellhousing. And I couldn't stomach the idea of a 4WD like skid plate under the car. So, the engine is staying in its stock vertical position, but I might be able to move it back a (very) small amount.
Old Jul 20, 2007 | 11:44 PM
Artsvette73's Avatar
Artsvette73
You will have clearence issues with the steering gear as it sits right below the oil pan. The hood is a better choice
Old Jul 21, 2007 | 01:43 AM
Z-man's Avatar
Z-man
Maybe you could just let some air out of the tires....
Old Jul 22, 2007 | 10:36 PM
Michel B's Avatar
Michel B
Funny, I saw this same quote in another thread, must work wonders
lol, OK, I must admit that negative responses gives me more motivation to try something out of the ordinary. I want to stay away from a hood mod or replacement, its important to me to keep the stock look.
Although I'm on vacation and told myself not to go in the garage, I could not help it. If I needed 7/8inch drop to accomodate the stock cowl induction aircleaner, theoretically I need at least say 1 inch clearance. I could live with that.
Around the fan and cowl, no problem, lots of room. checked the bottom area, pan, bell housing, again no problem, steering link is quite lower than the pan so it can work, the only place I can see having a problem is at the damper crossmember area, Its a tight spot. So I have a challenge. Anything can be modified, I will think about this.
Old Jul 23, 2007 | 12:07 AM
...Roger...'s Avatar
...Roger...
It will drop an inch as long as you dont have a PS pump on it.Just think of all the things you will have to modify to compensate.I saw a 69 sb at a car show that the guy modified the hood for extra clearance.He did it over the entire hood with the same thing in mind-not being able to tell it was changed.You would have needed a Nascar template to tell the it wasnt stock.
Old Jul 23, 2007 | 01:50 AM
palamesa's Avatar
palamesa
Here is my 350 before I pulled it. http://s187.photobucket.com/albums/x...t=DSC03713.jpg Looks like the pullys clear the frame. As posted, move the PS pump. Consider switching to electric fans to eliminate the mechanical alignment from WP to fan. Lower the trans mount the same distance. You MAY have to do some pinion adjustment on the diff if you develop a vibration. Possible mod needed to exhaust. Shifter linkage? Avoid speed bumps, these are pretty low to start with.
Have you seen any of the recent threads from the guys who have put after market hoods on? They are awesome and look like they came from the factory that way. If not, do a search. I really like them and I'll be putting one on mine. Good Luck..gp
Old Jul 23, 2007 | 07:30 PM
Michel B's Avatar
Michel B
Your comments are realistic, Thanks
Old Jul 23, 2007 | 08:56 PM
72LS1Vette's Avatar
72LS1Vette
By far the cheapest alternative is to get a dropped air cleaner housing and a thinner air cleaner.
Rick B.
Old Jul 23, 2007 | 10:07 PM
Michel B's Avatar
Michel B
Rick B.
The problem is,, I want to keep the original filter assy (cowl induction). this was in production 73/75. I think its cool and looks good under the hood. I'm going to start shopping for a replacement intake, I'm going to lose some performance but its worth it. The edelbrock 2101 is a good alternative, unless someone can suggest something else ???.
Old Jul 23, 2007 | 10:24 PM
trw's Avatar
trw
You might try putting new body mounts and some spacers and lift the body.
I am sure it (the body mounts) have settled some.
Just a thought.
Terry
Old Jul 24, 2007 | 10:27 PM
Michel B's Avatar
Michel B
Just a thought.
Terry
Your idea is very good, I just spent the winter rebuilding the bird cage pillars and replaceing the rockers and all the body mount brackets, I installed polly bushings. I certainlly gained some hight considering the condition it was in,,,,,will have to measure once the hood is back on.
Old Jul 24, 2007 | 10:48 PM
gkull's Avatar
gkull
I've have seen lowered motors on vintage race cars. They appeared to have stock reenforced frames. They spaced the steering frame mounting points down. Then they had home made solid motor mounts. They made their own power steering brackets.
Old Jul 24, 2007 | 11:44 PM
fauxrs2's Avatar
fauxrs2
beware of altered driveline geometry - at the very least you will need to change the pinion angle to maintain the proper relationship between transmission output shaft and pinion input - just lowering the engine/tranny (i presume you are lowering the tranny an equivelant amount and not angling the motor forward) will alter driveshaft angles.
Crankshaft pully may be an issue...i havent looked down there lately.. its darn close no matter how you look at it. - notching the crossmember is of course an option.
Other possibilites:
Clearance between slipyoke of tranny and parking brake cable?
Old Jul 25, 2007 | 07:05 PM
68/70Vette's Avatar
68/70Vette
Lot of people have reported problems if the transmission output yoke, the driveshaft, and the pinion yoke are not in a straight line. If you lower the engine, you might have to lower/notch the transmission crossmember, and also adjust differential pinion downward to maintain the straight geometry.
Old Jul 25, 2007 | 07:14 PM
palamesa's Avatar
palamesa
I started this thread a few days ago on this topic. It dropped off pretty quick....gp
http://forums.corvetteforum.com/show....php?t=1766012
Old Jul 25, 2007 | 10:23 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
I think the crank pulley and the power steering pulley will find the frame first.
To Lowering engine ??
