anyone ever replaced a door hinge?
Old Jul 21, 2007 | 01:32 AM
74vert's Avatar
74vert
Default anyone ever replaced a door hinge?
I have a 69 coupe. The left side (drivers) upper door hinge is broken. Is this something that can be bolted on and off or is a weld/epoxy on deal? Does this front fender have to be removed to replace it?
Old Jul 21, 2007 | 02:00 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
The inside bolts are accessible under the dash pads for the upper hinges, and under the kick panels for the lowers. The door-side bolts require the removal of the door panel. The uppers are under a bolt on access panel, the lowers have an opening in the door metal under the panel.
There's probably a thread or two in the archives with details and/or photos: http://forums.corvetteforum.com/show....php?t=1603168
Old Jul 21, 2007 | 02:27 AM
74vert's Avatar
74vert
Thanks. I did a little archive digging but mostly found hinge bushing and spring repairs.
Old Jul 21, 2007 | 03:05 AM
73, Dark Blue 454's Avatar
73, Dark Blue 454
You're gonna have to remove the upper and lower dash,..or at least I did. I don't see any other way to remove the four upper hinge bolts that attach to the birdcage.
Also, GM still makes the hinge.
Good luck!
Old Jul 21, 2007 | 03:30 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Remove the dash panel and the access panel on the door. It's pretty self-explanatory how to remove/install the hinge...just three or four bolts on each side (I forget, it's been a while since I've pulled one).
Make sure the door is supported, they're rather heavy.
To anyone ever replaced a door hinge?
